Hydraulic leak
/ Hydraulic leak #1
Lac du bonnet
1986 yam are j186d
Yanmar y186d
Live in a freezing climate - 25 f
After using the tractor and parking it and it cools down to -25f oil will show on the floor maybe liter .this only seems to occur in the winter months not above freezing months .
Thx
Don
/ Hydraulic leak #2
Yanmar y186d
Thx
Don
Don,
Hydraulic leak from hoses? Fittings? Gaskets?
-25F is drastic. Both Yanmar and John Deere require J20D for hydraulic fluid in extreme low temperatures.
Or in 20L bottle.
/ Hydraulic leak
Yanmar y186d
Thx
Don
It
Don,
Or in 20L bottle.
Thx makes sense !
/ Hydraulic leak #4
Are you sure it's hydraulic fluid? I've had many hydraulic leaks, but have only seen them while the equipment is running.
I've had engine oil leaks while the engine is cold though, probable a gasket gone bad.
/ Hydraulic leak #5
This is a common occurrence in the Yanmar/Deere/Cub Cadets that are used below -10F. The normal hydraulic fluid gets too thick and builds up too much pressure and wants to weep out. Thus, the low viscosity formula needs to be used.
As for leaks at other times and temperatures, yes, check seals, o-rings and gaskets.
/ Hydraulic leak
Thx certainly makes sense ! Don
/ Hydraulic leak #7
Don, for you - the parts manual compliments of the Yanmar Tractor Owners Group on GroupsIO. Link in my signature below.
  • YANMAR 3T22HA-F 3T72HA 3T72HA-F 3T72HA-S YM186 YM186D 0CT10-M22801_en.pdf
/ Hydraulic leak #8
From member rScotty brochures
Tractor Ernie had these posted some time ago,
If your leaks were with the power steering, it's a typical occurrence too.
  • YM186D YPS Power Steering Manual.pdf
2019 Kubota KX057-4 (A64126)
2019 Kubota...
John Deere Pallet Forks (A66285)
John Deere Pallet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
17395SFL (A61568)
17395SFL (A61568)
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
