Bx bucket issues
/ Bx bucket issues
Based on comments above about 3pt lift lever in raise position and my own observations, play with the mower deck/3pt lever to make sure it is not trying to raise your mower deck before the pressure check. My BX2230 sticks once in a great while, but dad's BX2230 sticks quite often. And when it sticks, the FEL doesn't move very fast. Speeding up the throttle usually kicks out the 3pt lever when it reaches the up position, the the FEL works correctly. Hope this helps. Jon
Ya playing with the 3pt lever didnt do squat today...it wouldn't even raise the 3pt. Levers ugh.....
/ Bx bucket issues #22
I read through your thread about replacing the pump and I did not see where you came up with a definitive reason for the pump failure. Did you find out why the pump failed? If not I can't help thinking that it was a symptom of the problem and not the reason which is why you are having continuing hydraulic issues.
Maybe its time to hit the reset button and go back to figure out why the pump failed before spending more on repairs that may not fix the real issue.
Despite what was posted I don't see any way for the pump to have such a catastrophic failure unless very high pressures were developed that caused the case to fail. I did not note any outside damage from striking an object and oil failure, low oil, etc. would most likely show up as wear on the pump with decreasing output, not catastrophic failure.
You know local Kubota techs, so they may be able to seek guidance from Kubota about possible causes and/or other similar cases.
/ Bx bucket issues #23
...Maybe its time to hit the reset button and go back to figure out why the pump failed before spending more on repairs that may not fix the real issue.
...Despite what was posted I don't see any way for the pump to have such a catastrophic failure unless very high pressures were developed that caused the case to fail.
It would seem that the system pressure relief valve should open and prevent catastrophic high pressure. Might be wise to check the PRV and make sure it looks operational. This would require removing it, which seems to be a rather easy thing to do, as some people have reported adding shims to the PRV to increase the system hydraulic pressure.
As FX...413 implied, it would be wise to get a pressure gauge hooked up and check the system pressure to be sure it is within spec.
Edit: Just an afterthought, but are you the original owner? If not, no telling what a previous owner might have done to jack up the system pressure to get more lift from the loader, for example. This would have been done by changing the number of shims on the PRV to increase pressure. Don't recall if they are added or subtracted to change the trip point. Just another possible reason to check system pressure...
/ Bx bucket issues
I'm actually on the way out the door right now to get the correct fitting for my Gauge. I'm apparently the 2nd owner, so who knows what potential problems I inherited. The only thing I think that caused that failure was the fact we ran the machine out of hydraulic oil. It didnt crack the HST at that time, but I had to winch the tractor on the trailer and after refilling it and using it for 20 plus hours before failure it whinnied and had a hard time pulling a lil incline ...
/ Bx bucket issues
Hey Fx413 thanks for trying to help me out!
I'm apparently the 2nd owner, so who knows what potential problems I inherited. The only thing I think that caused that failure was the fact we ran the machine completely out of hydraulic oil. Spung a leak on a hose yet continued to use the mower :(
It didnt crack the HST at that time but I had to winch the tractor on the trailer and after refilling it and using it for 20 hours before failure it whinnied and had a hard time pulling a lil incline ...
Maybe its possible at the time of failure it messed up something internally with the 3 pt?
aybe
/ Bx bucket issues #26
aybe
If your 3 point can be lifted by hand and won't lift hydraulically, that concerns me.
Back to my original warning, it is possible you damaged the cylinder. Look under the seat at the cylinder case. Do you see any cracks?
I would be very concerned that your repairs are not finding the cause.
You ran it out of hydraulic fluid? Where di that much fluid go?
That tractor hold a lot of fliud and you would have to dump most of it before the HST would quit working.
/ Bx bucket issues #27
Is it possible that his catastrophic blow out of the pump is also caused by that deadheading hydraulic pressure?
doubtful since the failure was in the hydrostatic pump and not the implement circuit. implement pump and related components I suspect would fail from excessive pressure before the HST pump would.
/ Bx bucket issues #28
Implement - 3 point should be totally independent of the HST with exception of implement pump also supplies steering and charge flow to the HST. Agree failure appears to be fatigue or high pressure or possibly combination of both. Example: since back hoe could this have been used hard doing lower work on good footing where one could reach HST drive relief pressures pushing into a pile and eventually causing a fatigue failure, especially if previous owner jacked up the pressure for a little more push power. Normal failure on relief valve is stuck open so doubt a relief failure.
fytrfire,
wishing you the best on finding the source of this problem.
/ Bx bucket issues #29
Following up on question asked earlier - apologies if I missed the answer, or it was too obvious...
@ the OP: you said you "have the hose" referring to the hoses that will connect to the BH. But do you have them connected to bypass the Bh? Two connect to each other, and the other plugs into a connector on the tractor.
Just double-checking... and good luck.
[edit to add] Sorry, I lost track of which BX it was. Not the same as my '24 but the question stands - unless it doesn't apply to a '22. Shouldn't the hoses be re-routed (to other hose or connector) when not connected to the BH to provide a loop for return flow?
Z.
/ Bx bucket issues
Well all of the fluid went on the grass that we were cutting...:( We probably ran it for close to 2 hours after we noticed a pretty significant leak...
I am messing with the tractor now and I did not notice any cracks.
One question I have is this hose that goes to my backhoe I believe runs to the pressure relief valve not 100% on that... but does that not need to be in a closed loop? In other words I have the backhoe off right now would it hurt to connect that coupling to the mail and as circled in the picture?? It seems to me that the one and with a coupling could stay like it is because nothing's going to leak out but with the other male and open like that it seems like either fluid would be gushing out if that was on any kind of pressure side or it will be sucking air in??
Two out of the three quick coupling connections up by the bucket that come off the side of the engine I have pressure tested and I am getting nothing but yet there is some movement on operating the bucket ...
/ Bx bucket issues #31
The lines to the backhoe have to be connected together if not connected to the backhoe. Pressure relief is provided by the backhoe.
I once left the lines unconnected while disconnecting the backhoe. Started the B20 tractor to pull ahead and immediately deadheaded the tractor hydraulics and burst an unconnected line at idle. So thinking that supply line had no relief protection before the BH or 3pt lift valve. Maybe source of high pressure damage. That line also provides hydraulic flow looped to the 3pt lift.
Don’t know if your BX similar.
/ Bx bucket issues
STOP THE PRESSESS!!!!
I figured it out!!! All I had to do is plug the hose coming off the back that goes to the Backhoe into the other connection that the backhoe connects to and BINGO!!!!!
3pt goes up and down and well as the bucket without any hesitation etc!!!
Keep it simple right!!?
Thanks to all that have wrote in on this for me!! 🙏
/ Bx bucket issues #33
OP, in your picture with the yellow circle around two open connectors, what do those connect to on the backhoe? Or is one of those a line going to the backhoe? On my B26TLB, I blew a hose on a backhoe cylinder. I was able to shut down tractor, find those two fittings used to remove my hoe from the tractor and connected them together on the tractor side, and on the backhoe. I could then run/drive the backhoe unto the trailer to get the hose fixed on the backhoe. Your picture to me looks like those fittings in the yellow should be connected together after removing the backhoe. Does this help? Jon
/ Bx bucket issues #34
OP, great, you and I were typing at the same time. Glad you got it figured out. Jon
/ Bx bucket issues
Ya makes sense! Cant believe it was something soooo simple. As I was pressure testing things I looked at the back and thought thats weird why no fluid is coming out of the non hose connection...i thought it should b sucking air in or pouring fluid out of it. ..simple, simple, simple. Just glad everything seems operational now :)
/ Bx bucket issues #37
:giggle: (y)
One of my basic troubleshooting tenets is that it is usually something simple if it doesn't jump right out at you. I learned that when I worked part time at marine dealer as a mechanic and the old guy who owned the place would walk by any stubborn diagnostic problem we were trying to figure out and he would say "It's something simple." and he was right.
/ Bx bucket issues #39
Thanks for getting back to us. It helps to know the final fix
/ Bx bucket issues #40
That is what I asked you in post #3.
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63118)
2012 Freightliner...
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
John Deere 335 Round Baler Baler (A64047)
John Deere 335...
429858 (A61165)
429858 (A61165)
Butler MFG Water Tanker (A63118)
Butler MFG Water...
