What's wrong with Canadians?
   / What's wrong with Canadians? #51
I've seen small fires under some equipment to warm up the oil so the machine would start. Ether was used a lot too...
This was Howard County, MD in the late 1960's
I agree...too much "news" (not just the weather) is sensationalized way too much...and that ain't just Canada. One of my current favorites is "potentially hazardous asteroid to fly by Earth"...then, buried in the article, the "potential hazard" is 600 years in the future...
I've done that also, except with a Coleman white gas heater. I had a rear flat on a MF175 and had to leave the tractor in the woods. We had a cold snap and I had to either start a fire underneath or wait until spring... and it was a borrowed tractor.
Now I don't borrow anything.
   / What's wrong with Canadians? #52
My older daughter married a California guy. Never been to a cold climate. They came for Christmas on year. was around -25 when they landed. His comment going to the truck " not too bad" On the way home I opened his side window, had him put his hand out. Next comment "#@%^& is that cold" Welcome to Canada and WINDCHILL my boy.
I married a canadian...I have to tell her to toughen up all the time.
   / What's wrong with Canadians? #53
Just heard on my way home that it will be bitter cold. Might get all the way down to 19. The average High where I grew up will be about 10 degrees over the next 5 days. Growing up, bitter cold would have been reserved for 20 Below Zero.
Of course, around here when the low is 32 people are covering their faucets and plants due to freeze warnings.
While wind chill and heat indices are real things, they don't make any sense in the context they use. Not sure if it is for click bait or for political gain, but sensationalized weather is a thing.
When my brother lived in Arizona he used to laugh about that. When below freezing overnight temps were predicted they'd say "Cover your swimming pool so that it doesn't freeze." I never took physics, yet even I know how crazy that is.
   / What's wrong with Canadians? #54
I've seen what they call "RealFeel" weather temperature reports here in the States. I guess not many on this side of the 49th can make logical deductions. It could be the afliction is heading north.
Growing up in North Dakota, we had a Thing about Canada. We all liked Canada, it was the Canuks that were a bit odd. Molsens was OK though.
Now, I don't get why every time it snows it's called a storm. Cripe, If you can still get out, and it doesn't kill all the livestock, it's just snow. Same as a summer rain only dry. Sometimes it did get chilly with the wind.
A "Perfect winter's day" is still 0 degrees f, no wind and bright sunshine. Call it good until about 3:30 in the afternoon. Then Break out the mukluks and mittens. And don't forget the hat!
   / What's wrong with Canadians? #55
evaporative cooling in AZ. Back yard skating is a thing ;-)
   / What's wrong with Canadians? #56
Snobdds you stated " I married a canadian...I have to tell her to toughen up all the time." .............. my reply would be .......your lucky to have her, I imagine she would have to be " tough " to put up with you ;)
   / What's wrong with Canadians? #57
IIRC over 85% of Canadians live withing 30 miles of the US border.
I was under the impression they felt that if escape were necessary, they didn't want far to go.
   / What's wrong with Canadians? #58
Oh she's tough...see a picture of my little Canadian on page 1. She has the quickest wit...even faster than mine.
She also has a sense of humor and knows not to take me seriously.
   / What's wrong with Canadians? #59
The pool might not freeze. but the sprinklers might.
I was living in Las Vegas when they had the first day on record when it didn’t get above freezing. Nearly every house, office, or building of any kind has a sprinkler system that they don’t winterize, and that is above ground. At that time they were still sprinkling bushes in the middle of the freeway, and that froze, burst and then flowed across I-15 turning into ice. And, a fun time was had by all.
The second night the sprinkler manifolds all started bursting as they froze. Most folks had no idea how to turn their sprinkler system off. Some installed by handymen and homeowners didn’t have separate shut offs, other than the one for the entire house.
The Water District, sent any employee who could walk out with valve wrenches, to shut off the meter to any house that had water running to the gutter. There had been so much water flowing that reservoirs were emptying and they no longer had fire flow pressure in parts of the valley.
I was living in a rental, going to college. The first night, when they warned it might freeze, I went out and put my biggest Coleman cooler upside down over the sprinkler manifold, unplugged the sprinkler clock, and plugged in a drop light with a 100-Watt bulb and put it under the cooler with the sprinkler manifold, then threw an old sleeping bag over the top. The Landlord called to say he couldn’t get over to fix my sprinklers for a couple of days. He was very relieved when I told him that the pipe didn’t freeze. And, when I told him that we had already dug down and installed a shutoff valve on the feed line, he took $200 off the rent. Many beers, and much pizza were had by all…
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
