@Jeepnford
So if my thinking is correct your DX35 is basically the same as a NH TC35 (or TC35D depending if your is the deluxe model or not).... If that is the case...
The fact your tractor turns over but does not start leads me to think of a couple quick things to check.
First off the seat safety switch and the parking brake switch will not stop the engine from turning over, no matter which position the y are in, they do however shut off the fuel solenoid. This will cause the tractor to die quickly & then create a engine crank with no start scenario.
First thing I would check is to see if the seat safety switch is working & the wires going to it... you can jumper the switch to see if the tractor starts...
Second thing I would check is to see if the Fuel Solenoid is working...
The fuel solenoid is on the right side of the tractor (same side as the ignition switch) it's down by the oil filter. If you set the parking brake and turn on the key, you should be able to hear it click or you can turn the key to the on position, and remove the wire clip from the fuel solenoid, listen for a slight click when disconnected, & when reattaching it. If you don't hear it click either the solenoid is bad or it is not getting 12 volt to power it... I would check to see if you have 12V at the solenoid when the key is on & the parking break is set (there is only one wire on the solenoid, it grounds thru the chassis).
If you don't have 12V power at the solenoid you have a a problem with the seat switch, fuel shut-off relay, or the operator safety module if your tractor has one.
If you do have 12V power at the solenoid... I would test the solenoid. (I've included the test procedure for the NH TC series)
Hope this helps...
