RK37 regen
/ RK37 regen #1
DonRybak
Gold Member
Central FL
RK37HC
My RK37HC now has 64 hours on it and I have yet to see a regen request. Several months back I seem to remember someone mentioning that theirs did a regen right at 50 hours when the first service was due. Just curious at what point other RK37 owners are seeing for having to start the regen process. Thanks..........Don
/ RK37 regen #2
At 41 hours on RK55, haven't had a regen request yet either, although the high-temp exhaust indicator on the LCD display lit up for a little while operating for a couple hours at low RPMs - but went out. We regularly run the engine at 2000rpm+, so maybe if you are doing the same, it has been hot enough to burn the soot in the DPF...? Dunno. Just spitballin'...
/ RK37 regen
Thanks for the reply markie69 but the RK 37 is different than the RK55 I believe. If I'm not mistaken the RK 55 will do a regen while being used where as the RK37 has a regen button that flashes telling you that it's due. If I'm reading the manual correctly it says to park the tractor then press the regen button that's flashing to start the process. Says that the tractor rpm will increase and to let the process run until complete which takes approximately 30 minutes......Don
/ RK37 regen #4
... the RK 37 is different
Could be they are different. This is my first Tier IV diesel, so don't know much (yet) about newer diesels - car, truck, or tractor...
/ RK37 regen #5
Can't speak to the 37 but the 55 will do it both ways. If you are running it hot then the Regen light will come on solid while you are running the tractor and go off when the Regen is finished, no user intervention required (my first Regen went like this). If you are not running it hot then it will request a Regen and you have to park it and hit the button to let it do it's own managed Regen (did this on my second one).
/ RK37 regen #6
My 37 did a regen at 50, 80, 134, 167, 189, 234 hours. Should be getting close to the next one since it’s almost at 300 now.
Every time it’s done it all I did was either crank up the throttle if I wasn’t working, or if I was then I kept right on working. About 25-30 minutes and it’s done. No button pushing and the only difference was the very distinct smell. I always notice it’s in regen by the smell first before I ever notice the light on the dash.
/ RK37 regen
kkilli, on page 2-14 of my manual it states that when the regen button starts flashing that you have to press the button to start the process. It also states that no other work should be done while the regen is in progress.
/ RK37 regen #8
“If” the light flashes....mine has never flashed. It’s gone on solid and as long as rpms are up it will complete without issue in under 30 minutes.
Pressing the button is for manually starting the process that either hasn’t started automatically or was stopped/hasn’t completed for some reason.
Like I said, mine has been through it 6 times in a little over a year. It’s no big deal, don’t over think it....
/ RK37 regen #12
Sure! Is called "gasoline".
Which is probably good enough for homeowner tractors. The downside is you lose the macho effect. Probably the biggest actual problem is fuel storage. A lot of homeowner tractors sit a long time between usage. For commercial equipment it’s not as good of an option. I’m kinda surprised no tractor manufacture is offering that option and see if the $$ makes the decision.
/ RK37 regen #13
I don't own the RK37 but I was talking with the manager at my local RK when I was tractor shopping and the RK37 was something I heavily considered. The manager mentioned to me that it has "passive" filtering and "active" filtering. So if you're constantly running PTO implements or keeping it revved up high, you're most likely keeping it above the 1800 or so RPMs it looks for. This keeps the DPF hot enough to keep the DPF clean-ish. DPF's have a sensor that reads the soot level and won't set it off unless it gets clogged up enough to need it. He told me he's heard of people going past 80-90 hours and still not having a cycle. Don't know how true it is, because he was trying to convince me to buy it, but it sounds pretty probable to me.
/ RK37 regen
MF1735Guy, thanks for the thought. Sounds very reasonable to me because 90% of my use is mowing my pasture which keeps the rpm up between 2000 - 2300. We use to have a member on this forum that was the lead RK tractor rep and he jumped in quite often to answer issues such as this. But he left RK back in July if I remember correctly. I'll be heading to RK this weekend for horse feed so if I see the lead tractor guy there I'll see what his opinion is......Don
/ RK37 regen
MF1735Guy, you were spot on with the thought of the non-regen issue. I talked with the tractor rep over the weekend and he said the regen is kicked off by carbon buildup on the sensor. Working the tractor hard keeps the rpm up so that most of the carbon gets burned off so the sensor doesn't start the regen cycle. Can't believe that never crossed my mind. Thanks again.......Don
/ RK37 regen #16
That's good to hear. Glad I could help.
/ RK37 regen #17
That I know of, on Ford Powerstroke diesels the DPF has fore and aft pressure sensors, and temperature sensors. Regeneration occurs when the DPF is blocked sufficiently by soot. The temperature sensors verify something is really happening, and that not too much is happening.
During regeneration the fuel injectors fire during an exhaust cycle with exhaust valves open to provide raw fuel to heat the DPF. Problem is that this results in oil dilution with raw diesel fuel.
/ RK37 regen #18
My personal pinion and experience is that RK tractors are garbage and would never recommend one, and have told everyone I know and even people at the local RK to run away as fast as you can and don't look back. But I guess it goes back to that day ole saying " you get what you pay for", but hell I didn't even get that before I had to start dumping money into ours. Broke down with tranny problems just after first payment, want to chrge me $3000 to fix because they said" Well you dented the front bumper so you caused it" really I wanted to ask for a glass of water to wash down the load of **** he was feeding me but was told don't even say it.
/ RK37 regen #19
I’ve only operated one machine that was equipped with that garbage but what you describe is far from accurate. It revved to about 1800 or didn’t rev at all if your were already above that rpm. Definitely not “wide open”. And you continued working as normal. If it wasn’t for the indicator you’d probably never notice. You didn’t have to take a 30 minute coffee break and wait for it to finish the cycle.
That is correct. The higher rpm produces sufficient heat to burn off particulates. You can simply continue work, and then return "normal" operation. But I always thought "normal Operation" was always at high rpm anyway. And there is not exact number for the process. It happens when your filter needs to be burned off. If you run low rpm or idle a lot, that may be a low number of hours to regen.
/ RK37 regen #20
169 hours on my RK37 and have yet to see a forced regen cycle. I've had 3 or 4 "passive" auto-regens where the display showed the high exhaust temp and I could smell the diesel being dumped. Just kept on working through those.
2014 FORD F150 4X4 PICKUP TRUCK (A59909)
2014 FORD F150 4X4...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
2014 Subaru XV Crosstrek SUV (A61569)
2014 Subaru XV...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
Bush Hog 327R-1 84in. Rotary Brush Cutter Tractor Attachment (A61567)
Bush Hog 327R-1...
