how do you remove the cab on a tool cat
   / how do you remove the cab on a tool cat #1
Dom Giusti
bobcat tool cat
   / how do you remove the cab on a tool cat #2
Among other things....remove seats, F&R fenders, coolant reservoir, center console, disconnect battery, disconnect electrical items like fuse holders and grounds, disconnect steering pump, unplug a bunch of electrical connectors, disconnect heater hoses from core, remove bottom engine cover, remove cab bolts, remove doors, put strap through cab and lift with hoist.
First, get a manual for your series and follow steps.
   / how do you remove the cab on a tool cat #4
The manual walks you through exactly how to do it. Was very helpful. Why are you pulling the cab? I had to pull mine to determine which hydraulic hose was leaking and have access to replace it.
Engel 20' Boat (A50121)
Engel 20' Boat...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55218)
J and L Cargo...
2010 Ford Transit Connect Cargo Van (A55788)
2010 Ford Transit...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
UNUSED RAYTREE REDM32 - 32" HYD MULCHER (A54757)
UNUSED RAYTREE...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
