All-electric Bobcat compact track loader
/ All-electric Bobcat compact track loader #3
To add to that.... Bobcat is Korean made. Also there is another Korean made product to watch.
Hyundai Motor Company has closed their motor manufacturing plant. They will now become a all electric vehicle.
/ All-electric Bobcat compact track loader #4
There was a thread about electric construction equipment a while back where the electric backhoes sat next to a diesel generator all night to charge.
Brilliant...
/ All-electric Bobcat compact track loader #5
Sunbelt must be making a ****load of money, to be going down this rabbit hole.
/ All-electric Bobcat compact track loader #6
4 hours of run time and integrates cutting edge software….:cautious: And since it doesnt have traditional hydraulics, none of your old attachments will be compatible. Yay
/ All-electric Bobcat compact track loader #7
No hydraulics....interesting.
/ All-electric Bobcat compact track loader #9
HOW MUCH???? Skid steers are already terrible expensive. Can't believe there will be a "Used" market for any electric vehicles unless they extend the warranty.
/ All-electric Bobcat compact track loader #10
Yes, it will be interesting. It will not have an engine or hydraulics which is a big cost. Also, it might not need the extensive cooling system. It will have the battery, drive motors, and ball screw actuators instead of cylinders.
/ All-electric Bobcat compact track loader #13
Obviously not for everyone, but nice in areas where you are working in large buildings. I've done a few projects where we need big skidsteers and mini excavators with some weight indoors. And in occupied buildings. Nice not to have the fumes.
But ball-screw actuators? My knowledge is limited and dated, but aren't they incredibly weak and wear quickly? B the spec sheet, the rig is very strong, but I can see regular replacement of those actuators.
/ All-electric Bobcat compact track loader #14
Agreed.
Obviously not for everyone, there could be a use for them, say in buildings, or areas where sparks/engines are not allowed or are restricted.
/ All-electric Bobcat compact track loader #15
Brilliant...
All the "green/EV" market does is move the ICE and exhaust upstrea.
A ****load of taxpayer money via subsidies surely
/ All-electric Bobcat compact track loader #16
Awhile back VOLVO announced a small all electric excavator on facebook....
/ All-electric Bobcat compact track loader #18
I'm thinking the option of remote control would be easily adapted to this electric model.
/ All-electric Bobcat compact track loader #19
The most interesting thing to me about this is the choice of electric actuators over hydraulic cylinders for the loader portion. Hydraulics have the great advantage of being able to resist a lot more force than they can put out, i.e. once you release the controls the hydraulics can 'hold' absurd forces, which is great because we bash the machines into things (especially skid steers) a lot harder than we push and pull on things with hydraulics. Speaking in terms of 'shock loads', anyway. With an electric actuator any impact forces are actually going through the 'geartain' or transmission of the actuator. This is part of why ALL loaders and 3 pt hitches aren't already electric actuators. So either the issue is not as important as i thought or (more likely?) the bobcat uses such large and heavily built electric actuators that they are probably $3-5k EACH. Might STILL be cheaper than replacing every inch of the hydraulics in skid steer's loader system, but not really a compelling option until the rest of the hydraulic system to support the cylinders is just no longer there.
Meanwhile, i have a 50hp (capable) electric motor/controller/charger setup from an old electric car i parted out that was made by a failed EV startup in the early 90s. I also have a small skid steer with a ****ty engine. I've recently been thinking about trying to combine the two. But that would be just hooking an electric motor up to the existing tandem hydraulic pumps.
/ All-electric Bobcat compact track loader #20
Electric drive motors and ball screws have been used on CNC equipment since the 80's so the bugs should be ironed out by now.
Club Car Carryall 2 Electric Utility Cart (A64553)
Club Car Carryall...
2013 Infiniti JX35 AWD SUV (A64557)
2013 Infiniti JX35...
445 (A63290)
445 (A63290)
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
