Ford 7.3L Gas Engine
/ Ford 7.3L Gas Engine #342
I was asking because my son and daughter-in-law live in Baton Rouge. There is plenty of soft ground around there.
They are due west of me. We are in North St Tammany. Hard red clay here. Of course you can find mud if you look for it, but our place is high and generally hard.
/ Ford 7.3L Gas Engine #345
If you don’t need 4wd it’s a waste of money. Only you can answer that question. It does have the locking rear end, that is nice.
/ Ford 7.3L Gas Engine #346
I'd agree, especially if 2wd is very common in your area. Here a 2wd pickup is almost impossible to buy new the last few years unless you ordered it.
/ Ford 7.3L Gas Engine #347
I am still on the fence about it. A cattle/hay farmer we buy our hay from own 3 diesel trucks and 4 tractors-all 2wd. His advice was if I am somewhere I need 4wd, probably shouldn’t be there.
/ Ford 7.3L Gas Engine #350
You ever drive a 2wd truck with a heavy diesel in poor traction conditions? The rear end has no weight due to the heavy motor and you have to load the bed to get any traction. Or flip the lever to get great traction because the heavy motor provides weight to the front drive axle.
/ Ford 7.3L Gas Engine #351
Yes. I had a 2004 F250 2wd and knew how front heavy it was so tended to stay on gravel and pavement in wet conditions. That being said, if this truck was diesel, it would have to be 4wd. The last 2 diesels we owned were 4wd.
/ Ford 7.3L Gas Engine #352
2wd vs 4wd really depends on where you live. One of my properties is very flat with a water table about 4 feet down and lots of clay in the soil. When it rains a lot I have to put my truck in 4WD to get moving. It is like being on grease. My other properties have a lot of hills.
/ Ford 7.3L Gas Engine #353
Same here-you don’t sink, just slick like grease.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
2014 FORD E-SERIES 11 PASSENGER VAN (A67714)
2014 FORD E-SERIES...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2019 Autocar ACX...
