Ford 7.3L Gas Engine
/ Ford 7.3L Gas Engine #321
What do you consider heavy? All mine hauling 26k will get 10-12 on summer fuel and 18-20 empty.
With 4.89’s, empty I get about 16MPG in the Ram. Towing at the trucks limits, it drops to 10-11 average.
Gas isnt even possible for me and I always prefer an in-line six for off pedal and low end torque over a high revving V-8 diesel, which would end up using more fuel.
/ Ford 7.3L Gas Engine #322
15-20k. But the Cummins will pull heavier loads and still do it a 2500-2800 RPMs at highway speeds. It’s the massive torque and efficiency of an inline motor that makes this possible.
/ Ford 7.3L Gas Engine #323
Barely a V-8 in existence in a modern heavy OTR truck.
/ Ford 7.3L Gas Engine #325
I know this is re-hashing the diesel-vs-gas fight yet again but...
I have been a proponent of the "I'll never buy a complicated emissions restricted diesel truck" line. I have an older F450 with a 7.3PS and not so old Silverado 2500 with a 6.0 gas. Took the Silverado to OH to pick up a UTV. 4 tanks of fuel there and 4 tanks back. I have made the same run empty and its 2 tanks each way (650+ miles). So that's about 13 mpg empty and 6 mpg lightly loaded. The truck kept up with traffic just fine, but some hills and on-ramps got a little sketchy and wanting for power. And I wasn't pulling much weight. Just my equipment trailer (2,500lbs) and the UTV (1600lbs). I was not prepared for that.
/ Ford 7.3L Gas Engine #327
The thing about diesel vs gas engines is that diesel mpg doesn’t change very much empty or loaded/towing. I get about the same mileage in the city, on highways, loaded or empty. But usage greatly affects gas motor mpgs. And this was the same with my old VW diesel car.
/ Ford 7.3L Gas Engine #329
Well then, the Cummins is just more fuel efficient.
That it is.
My not-yet-broken-in 6.7 Cummins is averaging 2.5MPG more than my 6.4L Ford it replaced and revving much lower doing it.
I’m done with V-8 diesels.…well, maybe a Duramax if I start using a large hay truck to haul again.
/ Ford 7.3L Gas Engine #330
That it is.
A Cummins will also work well in a large hay truck. It’s significant that Cummins is the only light truck diesel that is also used in industrial equipment such as log skidders, etc… You won’t find a power stroke or Duramax in those applications.
/ Ford 7.3L Gas Engine #331
I never was brave enough to try to tow anything with my old Mercedes 240D :ROFLMAO:
/ Ford 7.3L Gas Engine #333
Like this one? ;)
/ Ford 7.3L Gas Engine #334
I looked at this one a couple days ago. On the fence about it, 2wd 3.55 gears
Well equipped for my needs. Was ordered then buyer backed out. Has 2 batteries and auxiliary switches, probably ordered for a police or fire department.
/ Ford 7.3L Gas Engine #335
/ Ford 7.3L Gas Engine #336
Resale? Where I live you can’t sell a 2wd truck.
We tend to keep trucks 10-15 years. Resale not a big issue for us. While I would like 4wd, it is not a necessity for us. We are more concerned with cost and practicality
/ Ford 7.3L Gas Engine #337
If it works for you and resale isn’t a factor, then buy what you like. In my region, dealers won’t even stock 2wd trucks.
/ Ford 7.3L Gas Engine #338
They have about a 60/40 4wd/2wd ratio here. I am in Louisiana
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2015 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2015 Ford F-250...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
