Rim guard or not? Why a ballast box instead of boxblade?
   / Rim guard or not? Why a ballast box instead of boxblade? #191
I’ve had a tractor now for about 12 years with rimguard in the tires. Keeping my fingers crossed I’ve never had a leak in the rear tires.
   / Rim guard or not? Why a ballast box instead of boxblade? #192
20 years with Calcium Chloride in my rear tires. Not single problem yet. Rimguard was not available n my area when I bought the tractor, but when I need to replace the tires, I'll go with Rimguard.
   / Rim guard or not? Why a ballast box instead of boxblade? #193
A backhoe is expensive, and frankly not something I could justify being I can rent a much better trackhow for a tiny percentage of what a backhoe would cost. And renting one doesn't stress my tractor.
Not to mention that your 3ph is useless when a backhoe is installed. And removal isn’t something that you do in 5 minutes.
   / Rim guard or not? Why a ballast box instead of boxblade? #194
I don’t know how long it takes, but I do know that CaCl will rust your rims eventually. Other non-corrosive options besides rimguard are bio-ballast, methanol and water, anti-freeze and water, window washing fluid. My dealer installed bio-ballast in my tires before delivery.
   / Rim guard or not? Why a ballast box instead of boxblade? #195
I disagree. A box blade is centered laterally on the rear of the tractor. The stabilizing force of the weight of the box blade behaves exactly the same as if all of the weight were concentrated where the center of gravity of the boxblade is (which would be centered left and right, assuming the boxblade is symmetrical).
Whether a boxblade or a ballast box does more for lateral stability depends on how low that weight is carried to the ground. A tall ballast box with a lot of weight up high (or a boxblade carried as high as the 3 point will lift it) does less for stability than a setup in which the weight is kept low.
Filled tires provide the bulk of the ballast below COG. Any heavy implement or box on the rear finishes the job.
   / Rim guard or not? Why a ballast box instead of boxblade? #196
I really wasn't suggesting that someone buy and install a backhoe for ballast. I just remarked that a backhoe has the capability of providing plenty of ballast. My post was "tongue in cheek" as noted.
   / Rim guard or not? Why a ballast box instead of boxblade? #197
Took mine 27 yrs to do so. (w tubes) Two dime size holes in the rim. Tigged them up, painted the rims w bridge paint and off I went.
If I put the stuff in again now, I'll be dead before I have to do it again.
   / Rim guard or not? Why a ballast box instead of boxblade? #198
I do agree with you, but, as others have noted, it also depends on if the tires are tube or tubeless. Tube tire rims will last longer because the fluid "should be" contained in the tube and not actively touching the metal rims.
   / Rim guard or not? Why a ballast box instead of boxblade? #199
At least until the tube statrs leaking, then the rims will rust faster than a tubeless setup, since leaking tubes allow exposure to both CaCl and air, whereas properly filled tubeless, the rims don't see air (or don't see much of it).
   / Rim guard or not? Why a ballast box instead of boxblade? #200
One thing nobody has mentioned is CUTS/SCUTS are small and adding fluids to tires are not going to make a lot of difference due to small tire size... There for rear ballast...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
1997 PETERBILT 387 CAB CHASSIS TRUCK (A59575)
1997 PETERBILT 387...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
