Diesel heater on Toolcat
/ Diesel heater on Toolcat #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
looking for someone who has mounted a Webasto evo coolant heater on a Toolcat, with temperatures of -25C the block heater barely does anything, this heater heats the coolant this would be a game changer as the Toolcat could be in a remote area and still start and run
this is the unit I am looking at
/ Diesel heater on Toolcat #3
Hmmm....a diesel fired coolant heater. Interesting.
/ Diesel heater on Toolcat #4
Interesting..... FYI, the OE block heater on my '09 Model D is a 400 watt freeze plug unit. Seems to me you if you have access, you could add more freeze plug units.
/ Diesel heater on Toolcat #5
The newer Toolcats with the Doosan engine use a dry-pocket type heater.
/ Diesel heater on Toolcat #6
I couldn't find much info on it but it runs on 12v but the fuel source for heating is diesel fuel. I would worry that the battery gets run down too far to start because of the heater. I would rather get a 120v tank unit in the heater hose and make sure i'm close to an outlet.
/ Diesel heater on Toolcat #7
I got one of those on my 4.0L Toyota on the back of one cylinder head and it's a meager 400 watts as well. It hardly does anything when it's really frigid outside.
I had two - 800 watt block heaters in the middle of the heads of a 85 Ford V-8. 2 hours of those being on and you could see it on the temp gauge needle when you turned the key on. Instant heat and instant start no matter how cold it was.
/ Diesel heater on Toolcat #8
this is the unit I am looking atView attachment 727807
Those units were "available" in some markets on Audi Skoda vehicles.
Webasto also makes a fuel oil fired air heater that is used to heat the cabs on over the road trucks and small watercraft. The "overland" 4 wheeling pickup truck crowd has latched onto those for winter camping in tents and the like.
12 hour burn time on a gallon of fuel, and the vehicle battery is not seriously drawn down* (temperature dependent I would suppose)
The European units make use of SS internals, the chyna knock offs are alu. Service life to follow construction. You get what you pay for.
/ Diesel heater on Toolcat #9
I know 90 minutes at 0 F didn't seem to heat it like it should.
A 400w heater ain't much fighting the cold AND wind.
/ Diesel heater on Toolcat #10
Here is the OP's thread about last winters issues on starting when cold.
Toolcat block heater
I think if I was up there and had to deal with those frigid temps, I would have put the Bobcat synthetic 5w-40 in it.
/ Diesel heater on Toolcat #11
Laurencen, I have never installed a Webasto but have installed a couple Espars on Dodge Cummins trucks. I believe Webasto and Espar are very similar. If I were considering of putting one on my 5610 I would look at installing it on the passenger side floor board and plumb the heating lines in via the cab heater glycol heater hoses. That location is also close to the fuel source.
In the pickup market it is common to plumb the hoses so that both the engine and cab heater are heated by the Espar.
If that location is objectionable then the only other spot I can think of would be in one of the rear cover storage pockets, but then you have the hassle of making the heater hoses and fuel line long enough to accommodate opening and closing the rear cover.
/ Diesel heater on Toolcat #12
don't neglect the exhaust vent if putting the unit in a cab.
ruffdog I have the thin oil, it has the dry bulb block heater good for -15C max and that is pushing it, 3 or 4 cycles of glow plugs and lots of cranking, the issue is we like winter vacations in Mexico unfortunately we return to a windy -30C down to -40C and the block heartier does nothing, hardly cranks.
the issue is with a driveway just over half mile from highway to house we can also have couple foot of snow and taller drifts, twice its caught us I have a heater workshop its parked in another 200 yards away no power at end of driveway
with one of these heaters the Toolcat can be at the end of driveway, it would heat coolant up in short order, you get instant heat out the heater once started and easy cranking at least thats the idea
Covid stopped us last couple years but have a trip booked end of January assuming our intrepid PM does not shut borders again, this unit I ordered can be programmed to come on at a preset time and day but even if I had to fire it up and wait half hour on the side of driveway with the wife its better than walking to the shop to clear a path
get the unit on the weekend and figure where to mount it out the way, was hoping someone had installed one at some point.
also this just heats the coolant, there are units that heat just the cab, had one on a boat and worked great the heat output was ducted inside, unit and exhaust outside, they are used lots on school busses, another does both coolant and cab heat, these units have lower heating for coolant and I need to cut a hole in the cab, not wanting to do this option
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
Wagon Wheel Bench (A64557)
Wagon Wheel Bench...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
