Building a custom home - HVAC options - could use a bit of help please!
/ Building a custom home - HVAC options - could use a bit of help please! #1
ameliasolis
ford raptor
Hi!
We are in the process of building a 3200 square foot custom home in North Carolina. We have been approached by the HVAC contractor and given three options for the systems we can choose (he has estimated a 2.5 ton system upstairs and a 3.5 ton system downstairs). They are all Trane systems and are:
Option #1: The XB1000 air conditioner (10 SEER) with the XE80 gas furnace for approximately $12,000***OR***
Option #2: The XR12 air conditioner (up to 13 SEER) with the XR90 gas furnance for approximately $15,000***OR***
Option #3: The XL14i air conditioner (up to 15 SEER)with the SV90 gas furnance for approximately $18,800.
Our questions are:
1. In light of the upcoming regulation changes, what would be the mininum expected requirement for a custom home?
2. What are the real differences in comfort one might feel in the different systems (I am more sensitive to heat and humidity versus cold)?
3. We are not on a gas line, therefore, we will be on propane and option #3 includes a two-stage gas furnance. What kind of savings can we expect to see with a two-stage system?
4. We have a fairly open floor plan; however, there were no deisgned-in locations for the return ducts. Our contractor has proposed two locations within 7 feet of each other (no barrier walls involved) for the first floor. Will this be sufficient to adequately draw air?
5. He has also presented the option of an electronic air cleaner at a cost of $1495 - are these worth that expense? Do they really help with dust?
Our general contractor has not offered the option of getting other "bids" to verify fair pricing and the HVAC company is ready to start working now. Any help, advice or guidance offered would be most appreciated.
Thanks!
/ Building a custom home - HVAC options - could use a bit of help please! #2
I've built 8 new houses in my life. I've always used "the best" option for HVAC. Never go on the cheap.
Based on the options your builder has given you, I'd seek out another quote on your own from another HVAC contractor. Carrier or Trane are both good systems. 15 seer is lower than I would go. They make equipment up to 20 seer now. Higher the seer the more efficient it is. I have 17 seer. Very efficient and low utility bills. And with you being on propane, the more efficient the better.
Also, you should be able to get a "zoned" system. One AC condensor, one furnace with 2 zones of ductwork. It's what I have in my home now. Works great. Separate thermostats for each zone. Costs a little more for ductwork installation, but lowers the overall costs on 2 condensors and furnaces.
And putting both return ducts 7' apart is mal-practice IMO. I'd never put them that close together. Contractor is trying to make it easy on himself (jeeze...there's a surprise).
And remind your builder whose house it is, and who is paying the bills. If you're not satisfied with his HVAC contractor he can easily find another for you. He just doesn't want to.
/ Building a custom home - HVAC options - could use a bit of help please! #3
I'd want to see the Manual J load calc and Manual S sizing that the HVAC contractor did. (or some alternate method other than guessing or what's in the warehouse). 6 tons for a modern well insulated and sealed 3200 sq ft house seems like a lot.
Where you are (not too cold) heat pumps or even mini splits or small ducted systems may make sense, especially if your electricity rates are low compared to propane costs. Or even better if you have or plan to have solar.
Ducting (for a ducted system) is really important. Our house built in the '80s came with just one return. We had one added which took some fancy custom metal work for a plenum and it helped the system's performance. Make sure the ducts are large enough.
These days I'd want a variable speed/output furnace. It's more comfortable than the temp going up and down with a single speed/output setup. I wish our AC did that. That's one of the advantages of mini splits and other inverter based heat pumps, they can run longer at less output to keep the temperature more stable.
Your contractor should not rush you on this. If he didn't start you on making the decision far enough in advance that's his fault not yours.
/ Building a custom home - HVAC options - could use a bit of help please! #4
For answers to all your questions I suggest getting an evaluation and bit from a second HVAC contractor. They are NOT all the same. HVAC generally falls under the purview of a mechanical engineer. Finding one of them may be a wise investment. If your contractor doesn't offer the option of other bids is there anything to prevent doing so? Is the HVAC contractor in collusion with the general contractor? Perhaps a consultation with an attorney regarding your contract is in order.
/ Building a custom home - HVAC options - could use a bit of help please! #5
Another thing to consider is the ductwork material. It should be wrapped hard duct with only a short run of flexible duct (>5') to the register. 10 SEER is to low. In 2005, I put a 14 SEER 5 ton heat pump with a variable speed supply fan on a 3000 sq ft house. I agree with ericm and using the Manual J to size the units. This is a code requirement in some jurisdictions. Most major brands (Trane, Carrier, York) are good and manufacture most of the secondary brands.
/ Building a custom home - HVAC options - could use a bit of help please! #6
I HAVE A 2500 SQ.FT HOUSE, HAD A 15 SEER -3 TON-HEAT PUMP/AIT CONDITIONER INSTALLED LAST YEAR AND LOVE IT. HEAT DOWN TO ABOUT 35 AND AIR WHEN IT HOT. I HEAT WITH FUEL AND THE HEAT MODE HAS SAVED ME A LOT OF FUEL. I HAD 5 OR 6 QUOTES FROM 15K TO 6K.
/ Building a custom home - HVAC options - could use a bit of help please! #7
We have a comparable size all-electric home, 3200 square feet on 1 floor with a Trane 3.5 ton for the living areas and Trane 2.5 ton for the 3 bedrooms. They were installed in 2009 and are 14 SEER. The entry way which has 17' ceilings has ducts from both systems feeding it as it has a dormer and gets the west sun. We have auto season thermostats set from 68 - 72 degrees year-round. The house also feeds the barn which has a mini-split system in the tack room. Between the 2 buildings there are 4 refrigerators, 3 hot water heaters, and 2 laundry rooms. We have average billing which is running around $250/month on coop electric at $0.105/KWH.
I would go with the best system you can afford but also put your money into insulation. We also have R15 blown insulation in the walls, R44 blown in the attic, and double pane insulated windows. The deck sheeting on both the house and the barn is the reflective sheeting which prevents radiant heat coming into the attic, similar to LP Techshield as an example. Along with good ventilation the attic stays tolerable even in the summer, lessening the amount of heat radiating into the house.
/ Building a custom home - HVAC options - could use a bit of help please! #8
Here is a picture showing the reflective deck boards. It is installed with the foil side down. If you zoom in you can see the instructions saying that.
/ Building a custom home - HVAC options - could use a bit of help please! #9
I believe the past 2 issues, or maybe three issues of Fine Homebuilding will answer the questions you should be asking. One issue talks about leaky houses and controlling air. I am pretty sure one of the issues talks about SEER. In days of old you could go to the library to look at magazines. Not sure if libraries do that anymore. They may have digital magazine subscriptions.
I have a geothermal system in my house. I love the not hot heat. I mean the heat comes on and warms things up and turns off. When it turns off you do not feel like you walked from standing in the sun to standing in the shade. Of course some of that could just be my mother's leaky slab house versus my not as leaky house with a basement.
/ Building a custom home - HVAC options - could use a bit of help please! #10
Geo uses a lower air volume as well and makes for a very quiet system. Usually never even know if ours is on or off.
If you get a chance do a blower door test prior to sheetrock to help with air sealing.
/ Building a custom home - HVAC options - could use a bit of help please! #11
We are in the process of upgrading our 17 year old 80% propane furnace and 5 ton split unit to mini splits. About 18 months ago I upgraded the master BR and bath to minis. It allows us to have the temp we want at night while sleeping without heating or cooling the whole house. We absolutely loved it so much that now I am converting the whole house to mini splits.
The units are almost silent the air handler fan runs at a low speed constantly so the air keeps circulation and the hot air does not concentrate at the ceiling. The temps are very consistent throughout the room.
Since the compressors are inverters they constantly vary the load saving a lot of power. The original 18K with two 9K splits unit only draws 4 amps 240v on my clamp on meter when fully on.
The best part is that the SEER is 22!
There are a few downsides. First each air handler has it’s own thermostat, but that can be handled by using a phone app to control each unit as they are internet connected. It’s nice to come home to a warm house when gone for the day.
The second this is that because we are in the desert, we have a whole house humidifier for use in the winter heating season. We have been using a small humidifier in the BR and will probably have to get a large unit for the great room.
/ Building a custom home - HVAC options - could use a bit of help please! #12
We have a similar setup only with geo and zoned duct. 6 separate zones with whole house humidifier tied in.. Master is alone on one of those zones. Having the zone controls is really nice.
/ Building a custom home - HVAC options - could use a bit of help please! #13
<snip> the HVAC company is ready to start working now. Any help, advice or guidance offered would be most appreciated.
Thanks!
If he's ready to start working NOW it's a little late BUT
Look into mini-splits.
Unless you already have the ductwork planned for and installed it's a much easier installation.
/ Building a custom home - HVAC options - could use a bit of help please! #14
Hi!
Our questions are:
Thanks!
Google Green Building Advisor. There is a wealth of information related to HVAC systems.
Your hvac contractor should be performing a manual J calculation to size your system. If not, you should find someone that will.
As for returns, I would not build a new house without ducted returns in all bedrooms. If it’s too late, you can at least install a jumper duct from inside the bedroom to the hallway to help with flow.
I just had upstairs unit replaced this summer with the XL14i. So far now issues.
check utility providers as they may offer rebates with certain efficiencies of units. It won’t be enough to pay for upgrades but it might get you a couple hundred back.
If your ducts are ran in un-conditioned spaces, make sure they are sealed and insulated.
/ Building a custom home - HVAC options - could use a bit of help please! #15
If you go the zoning route, do so with a hvac co tractor that is knowledgeable about these systems. Otherwise may not go well.
/ Building a custom home - HVAC options - could use a bit of help please! #16
All these are good suggestions. The SEER you were quoted is way to low! Your monthly energy bills will be high. I have a 18 SEER 4 ton unit with spray foam insulation in 2200 sq ft. house. Insulation and sealing against air infiltration is very important and will have a big impact on your energy bills and what size of HVAC you'll need.
Fine Homebuilding was mentioned - that's an excellent source, but if you can't get ahold of the magazine, one of the frequent contributors is Matt Risinger who builds high end homes in the Austin area. He has videos on youtube, check them out.
Risinger on HVAC
Manual J calculations were mentioned. They are required by code. Where I am, inspections are not required and the HVAC contractors can not do a manual J calculation. They know generally what it is, but don't have the software to it, nor do they have the knowledge of what needs to go into a manual J calculation. There are also calculations for duct size which I think is a manual D calculation. So, I'd push for the manual J and D calculations, but you may not get anything or if you do it may be meaningless depending on where you are.
/ Building a custom home - HVAC options - could use a bit of help please! #17
In the newer tighter homes it is the indoor moisture you need to worry about. Everybody talks about sealing the home but how are you going to get the air exchanges. If you have bath fans, range hood where is make up are coming from? Basically you build a tight home then you have to poke a hole in it. How this is done also depends on where you live. Depending on where you live you want to run positive and negative pressure in your home at different times of year. In summer if you ac is not sized right so that it runs long enough to drop the humidity you can get it cold but it will not feel cold because the humidity is high. Where your at I would be looking at EVR and a whole house dehumidifier. And to get that more right they should be ducted when the house is new. You can use the whole house dehumidifier to dehumidify the make up air when coming into the home.
this as a lot of good information
/ Building a custom home - HVAC options - could use a bit of help please! #18
I wouldn't hesitate to go with cold climate mini-split heat pumps again. I've had mine for for 5years now and they work well down to -30oC.
Spend more money on better insulation, thermal breaks, air sealing, HRV, and most energy efficient doors and windows.
Remember that 80% of the building's cost during its lifetime is in the day to day operation, not the construction.
/ Building a custom home - HVAC options - could use a bit of help please! #19
Hi!
Our questions are:
Thanks!
Trane makes as good of equipment as anybody. I'd definitely recommend going with option #3 of the ones presented. Having separate units for upstairs and down does provide a basic level of "zoning", which is beneficial. Central systems can also provide much better air filtering than the mini-splits. I'd recommend exploring the air filters the builders are proposing as well. A big benefit of two stage or modulating units is the longer circulating fan cycle times in low stage operation, the house will feel more evenly heated/cooled, and have better humidity and dust control.
/ Building a custom home - HVAC options - could use a bit of help please! #20
The tradesman gets stuck in their own rut.
Find a contractor that's familiar with ductless mini splits. They are fantastic and those tin beaters guys in the rut will discourage you simply because it's out of their comfort zone of what they know. What they don't know is it's still the basic "thing" that they're doing every day without the tin.
Very comfortable
Very efficient and arguably a simpler and faster installation.
Don't confuse these with the pretty lousy ducted "heat pump" of the 80's & 90's, not even close.
AGT Industrial ExRC54 (A60463)
AGT Industrial...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
