Grading--what am I doing to cause this?
   / Grading--what am I doing to cause this? #11
I get that ripple effect when using the grader blade on my York rake. Once I get the road crowned, I fold the blade up and make a few higher speed passes using just the tines. Smoothes everything out nicely. Using the trolley wheels also helps.
   / Grading--what am I doing to cause this? #13
A box blade with ripper shanks would be a try also. The rippers would hopefully loosen up a couple inches of the surface ridding it of the ripples leaving it smooth. Gauge wheels behind the blade help tremendously also.
   / Grading--what am I doing to cause this? #14
When you're doing that grading, is there a nice pile of material in front of your blade? Or is the ground too hard, and you barely pull anything along?
Agree with all the other suggestions that it is probably just too light. Bolt a couple hundred pounds onto that blade and try again. Your idea to do it when conditions are damp is wise. Go slow if needed.
   / Grading--what am I doing to cause this? #15
This is why I don't like box blades, although considering where you are that actually doesn't look too bad. If you really want to get that road smooth maybe see if you can borrow a neighbors land plane. That'll do a far better job.
   / Grading--what am I doing to cause this? #16
My opinion is going to be different... It looks like you are cutting too much. Once the blade cuts into the ground, it wants to dig. What you got there is fine, NOW turn the blade backwards and drag the road forward, blade at an angle (it will smooth and not cut). OR use the box blade but this time extend the top link so that you are only riding on the rear blade (rear blade facing backward will not cut, but will only smooth the road out). It takes time and practice... post more photos of the road bed. If there are large rocks, you are going to have issues. Good Luck!
   / Grading--what am I doing to cause this? #17
That reminds me of another thing I can't understand, I try to set it so it's just barely touching the surface and take off,
I think that is your problem. The box blade needs to be set with the top link at the correct angle and lowered all the way down so it can float.
There are many threads here and YouTube videos showing how to do it.
   / Grading--what am I doing to cause this? #18
Once blade dig's in to create a ripple,more are created when tires go in and out on subsiquant trips. Slides long enough to bridge ripples help control blade oscillation as tractor tires go in and out of ripples. Additional weight on blade helps prevent blade riding up and over loose material.
From what has been suggested I agree with landplane or slides on box blade.
I strongly disagree with loosening additional dirt and rocks. There's enough loose matreial in your picture to fill low spots. If some ripples are present after soil is set up,shaving high spots for material to fill low spots is much better than ripping teeth. If your plane or box doesn't shave well,bring in material to fill low spots.
What MPH are you utilizing for grading? My guess is too fast.
That is possibly a part of it, I was often but not always going fairly fast. That, the weight, the hardess of the ground and likely the drop speed adjustment are all going to interact to some extent. I need to find the balance.
   / Grading--what am I doing to cause this? #20
My first rear blade - Land Pride 2584 @ 575#. It produced the EXACT same results as the photo in post #1. Just way too light for my looooong gravel driveway.
Now I have a Rhino 950 - 96" & 1050#. Go SLOW and angle the blade.
2010 Case 580N (A60462)
2010 Case 580N...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
