Ok, what is this?
/ Ok, what is this? #1
Acethe3rd
Mahindra 1533
I jumped on the tractor, Mahindra 1533 and hit the key. Lights started flashing everywhere and then a clicking noise underneath. This is on the left hand side of the tractor in the front. Battery is juiced. With the one problem. Tractor won’t crank and I can’t read a schematic from the dealership. I was suppose to buy a manual from Bill’s tractor but I can’t find my tractor on there. So much going on with barn build I can’t remember which manual I am suppose to get. Thank you.
/ Ok, what is this? #2
Check this thread out, hopefully they can help.
/ Ok, what is this? #3
I meant this thread.
/ Ok, what is this? #5
i second the check battery cables and battery connections at all points. also check voltages at end of cables while cranking engine. you can also ohm out cables.
/ Ok, what is this? #6
Yup, most likely bad/dirty connection @ battery
/ Ok, what is this?
Connections look loose and dirty. Might be as simple as cleaning them up and connecting them tightly. Doesn't hurt to try at least.
Will do.
/ Ok, what is this?
Checked battery connections first and all fine. i am going to clean things up and try it again. Thanks. 😀
/ Ok, what is this?
And that I will try Next. Thank you.
/ Ok, what is this?
That click, click at the end of the video is what I was hearing.
/ Ok, what is this?
Thank you. I will try it.
/ Ok, what is this?
We have done this today and zero power. No lights on dash, no, nothing.
/ Ok, what is this?
We took them apart, cleaned them checked them and reconnected Ed and nothing. No dash lights. Fuses are good, we have checked everything.
/ Ok, what is this? #14
On occasion I have noticed corrosion actually creeps its way along the inside of battery cables.
While voltage still flows high amperage does not.
The tip off is when that cable is not as flexible near the end as in the middle.
Slitting the insulation often shows a lot of powdery corrosion, this mostly near the battery.
However most problems often can be traced back to bad grounding.
Good grounds need to be clean bright metal surfaces.
/ Ok, what is this? #15
HOW did you "check"?
Not trying to be flip here, but some kinds of "checking" can fail to actually detect a problem. I've told this story before but I'll pull it out once again...
I was in the middle of a big project and a neighbor wanted to borrow my B7800. That tractor wasn't starting and I couldn't readily determine why: I really had ZERO time to be messing with it (I think the clock was running on some rental equipment I was using). Another neighbor volunteered to troubleshoot. That guy eventually gave up. I believe that he said the fuses were all good. When I finally got around to looking at the tractor myself I pulled and TESTED, with a meter, each fuse and found that one was bad- yes, THE FUSE that was responsible for starting (fuel solenoid and such, I believe). The fuses LOOKED good, but clearly that was an insufficient assessment.
CHECK YOUR GROUNDS! (also, those relays, clean off the lugs really good- pictures show poorly seated relays- it's possible that one of the relays is stuck- poor connection can cause it to over-heat, which then will make them stick; sometimes slamming the relay around, smacking it, can help- better is to just test them)
/ Ok, what is this? #16
The battery’s ground cable connection at the frame is the cause of many problems on TBN.
Don’t forget to disconnect and clean metal off there.
/ Ok, what is this?
They are. That is what we can’t get. Possibility we missed it under the cover on the positive where it crooks under. I am doing a double check again in a few minutes. Thanks!
/ Ok, what is this?
We took them all out, put the meter on them and they show up good. I am about to start a triple check so see if we missed something. My friend brought his multi meter and we made sure both were working correctly. After he checked things and I had already checked them, then I still have the feeling there is just some, little something we missed. Just finding it. He took the relays off and handed them to me. I cleaned the connectors good with a wire brush. I am about to start the process again. Never give up. Thank you!
/ Ok, what is this? #19
Back when I was in aviation we had a circuit that showed proper voltages but would not do its thing.
After much head scratching we discovered inner corrosion of the wiring was the culprit.
Keeping that revelation in mind I applied it to tractor and vehicle troubleshooting as a last resort.
Age and general overall condition is a reasonable clue once all else fails.
Bad or doubtful grounds can be determined usually by using a jumper directly from battery to a good engine bare metal point.
Many ground are via braided straps that easily corrode due to the braiding of that fine wire.
As to connectors, often pulling apart and re connecting is enough to re make a decent connection.
Adding a dab of contact cleaner is also not a bad idea. (WD40 is effective)
/ Ok, what is this? #20
Always test for voltages UNDER LOAD. For instance start with the lights turned on, and/or other loads. Now start on the battery post itself by measuring voltage. If good move on to the battery post clamp, if good move on the the other end of this large cable by measuring the voltage at the starter terminal. It is not uncommon to have full voltage at one end of a cable and zero volts at the other end with a load on that cable. WITHOUT a load, the voltage may read good on both ends. Now think about this for a bit, how can a wire have one voltage one one end and another voltage on the other end? BECAUSE often a wire is not a wire any more. With corrosion inside the wire under the cable sheath, where you cannot see it is a white/green corrosion mess that is now a big high value resistor. Without load even a very high resistor will show the same voltage on each end, With load, the resistor will show a drop in voltage whenever current is trying to be pulled. With this in mind, go back and start the voltage hunt again. Remember test under load.
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
(5) 10 X 20 STEEL MATS (A64276)
(5) 10 X 20 STEEL...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
