Bad news big repair
/ Bad news big repair #221
I thought of trying that last year, but I ran it by someone who was an electronics tech in the military and he thought it would not be a good idea since the tractors have different programming.
I was thinking of not even trying to start it but just cycling the glow plugs to see what happens. Probably not a good idea but it would be tempting.
/ Bad news big repair #222
Purchased my M135X in warmer months almost 3 years ago (April 2019). Never thought to see if the glow plugs worked. They actually won’t work if it’s over 41*.
Last winter, I realized the glow plugs weren’t working. Ohmed out wires, looked at wiring for mice damage, water damage, bad grounds, etc. Ohmed out wiring. Thats when I learned the glow plug system in larger kubotas is more complex than I thought. All 4 glow plugs passed electrical testing.
The glow plugs have 2 sensors one for air temp, one for water temp. The ignition switch is also part of the circuit. Then there are 2 relays and a fuse. All of this is controlled by the ECU. Last winter, I replaced
Key switch
water temp sensor
air temp sensor
both relays
fuse
Still no glow plugs. With nothing left to replace or test, I succumbed to a very reputable Kubota dealer. They basically did all the same things I did and replaced one of the new sensors I had already placed.
Still nothing. They called Kubotas double secret probation hotline and Kubota thinks it’s the ECU.
ECU price $6000 :(
ECU Not returnable and no guarantee it will fix glow plugs.
So I’m out of answers. Any thoughts on other possible avenues to pursue?
I'm thinking that by-passing all that complicated sensor stuff and just having a direct feed and a manual switch from the battery to the glow plugs might be worth investigating.
Or, if you're worried about forgetting that the manual switch is still 'on' whilst running the engine, add a timer relay that puts power into the glow plugs and drops the power after a preset period of time.
Good luck with the repair - I wouldn't contemplate changing out the ECU for that money!
Phil
/ Bad news big repair #223
Here is a thought. What if you tried the ECU out of the M126X to see if it would fire the glow plugs? At least then you would know if there is a problem with the ECU. Of course if it blows the glow plug circuit you will need two bypass switches. But that is cheap enough.
or it could be tested in about 5 minutes with a multimeter, with 0 risk
/ Bad news big repair #224
I see the thread has devolved into the same options repeated often. If your wiring diagram is like the one I posted, have you confirmed the voltages to the glow plug relay? Only thing the ECU should control is the ground that pulls the relay in to close the circuit that supplies 12v and a lot of amps to the glow plugs. As someone else mentioned on the VW TDI you turn the ignition on to activate the glow plugs before you activate the starter. On my JD 870 you turn the ignition switch counterclockwise to activate the intake heater. My Dodge truck you turn the ignition to run to activate the manifold heater. I thought I saw in the diagram that your tractor may also have a manifold heater.
If you did not watch over the field mechanic do you know if he or she did any multimeter testing? Corroded connections could be causing the relay to not work. I had my VW chip tuned years ago. That guy removed the ECU, opened the ECU, desoldered the computer chip, programmed the chip and soldered it back. Later tune from another company tuned from the OBD port. A bit of blah blah blah about I do not recall how the ECU box was split open.
I got a Scag zero turn "Died while mowing." Right go arm switch bypassed, fuse holder cut out and wire nutted, seat switch wire nutted, fuel pump not plugged into wiring harness but using wire nut. Dealer sold me wrong arm switches which took me a while to figure out. Sold me NC switches instead of Normally Open switches. PTO switch did not ohm out the way I liked so it was replaced. Plugged fuel pump into wiring harness. Replaced missing fuse holder and fuse. Proper arm switch installed. Jerry rigged throttle cable so it works properly. Starter circuit works again and engine runs. Horrible sound from mowing deck and crummy quality of cut. Bent deck and a lot of spindles with bad bearings. Driveshaft to gearbox also has bad bearings and destroyed seal journal surfaces. Mower deck cracked. Lots of grease fitting with factory paint on a 16 year old mower. Eventually I will get that deck straight, cracks welded, seal journals welded and turned back to size.
Anyhow if you have time, a multimeter and a helper you could figure out what is missing electrically from the glow plug relay and then trace that back to the ECU wiring plug. If you only had time and some daylight. That ground wire terminal 5 to the relay looks like you only have a few seconds to test on a cold day.
Yep, it’s not easy as it seems, and I am not an electronics expert, so I came seeking advice on fixing existing system. Thanks for suggestions
Wonder how long the tractor would be down waiting on them to rebuild the ECU?
Or if the ECU isn’t on its way out with other functions?
/ Bad news big repair #227
If it was a mechanical part, I'd do it. But electronics... if it blows you now have 2 machines that don't work.
I ran into a lot of this at my last job.... people wanting to swap boards from a good working machine into a bad non-working machine. We only had 2 machines, and they wanted me to possibly make them both dead. No way.
If I had at least a pair and a spare, I'd consider it. But not with just 2 machines.
/ Bad news big repair #228
Lots of pages I have not read here, but has it been mentioned that "some" glow/preheat components do not tolerate full 12V battery voltage during the heating process. That is, the multiple heaters (glow plugs) need an additional dropping resister to limit applied voltage to keep from burning out the heater elements. Some do, some do NOT.
The B7200 has a bare wire coil that heats and glows red , visible through a hole in the dash.
Such information and "matching of components" is important when jury rigging any work around.
Wouldn't want to burn out all the heaters and add to the cost of learning.
/ Bad news big repair #229
Yeah, that's a possibility. But at least you have a plan to get the glow plugs working if it's not the corrosion issue you mentioned. Then only time will tell if other functions of the ECU will go out.
/ Bad news big repair #230
Key switch
water temp sensor
air temp sensor
both relays
fuse
ECU price $6000 :(
Take a look at a cheap Chinese tractor. You will find a a spring loaded switch (some are on the keyswitch turn it left for glow plugs). A fuse and wire going to the glow plugs. Simple and it works. Good luck!
/ Bad news big repair #231
Gee, I remember you telling me everything you owned was pre 4. Guess you fibbed. Neither of my M's have a black box, thank goodness.
Lighten up Alice.
/ Bad news big repair #232
As mentioned in some previous posts: TANK OR BLOCK HEATERS. A much more reasonable fix. We have a 1972 JD 3020 and 2005 JD 6603 both without glowplugs. Using the heaters we never had any trouble starting these in our WI winters. Depending on the temp, plug in time varies. Sometimes if we are in a hurry a shot of ether will help. DO NOT over do the ether.
No AC power available…..
/ Bad news big repair #234
Well, considering that a block heater and radiator hose heater have been mentioned once or 1000 times now, I'll suggest something different. Mount one of those water heating solar panels on the roof of the tractor, connect it to the cooling system and park the tractor under the sun light. 🤣
/ Bad news big repair #235
A $200 generator will fix the lack of AC power, it only needs to run 30 minutes,,,
The $200 generator could run three or more magnetic block heaters, thus shortening the heat prior to start time,,
I used three heaters on my 584 IH the one time I needed to get it started when it was REALLY cold,
It started in about 15 minutes. (we hardly ever get cold enough to need any kind of start aid,,)
PLUS, you have a perfect generator for your net camping trip, no need to miss the big game on the TV!!
Yeah thats true.
I will add it to the list of possibilities
Going to try to see if corrosion of the ECU and plug fixes it first. If it doesn’t, will pursue on board DIY glow plug set up or maybe a generator to power a block heater.
I really should buy a small portable generator one of these days….
/ Bad news big repair #238
Especially in instances of corrosion an ohm meter may not detect the problem - you need to test using voltage to see if the wire/circuit is capable of the load. In my decades of auto diagnosing I used a headlight bulb rigged with wires to test integrity of 12vdc circuits. Alot of times it's not the connection between the pins/spades in the two halves of a connector but in the crimp/solder of the wire to the said pin/spade and in severe cases even up the wire under the insulation.
/ Bad news big repair #239
After cleaning, if it cures the issue, coat the connectors with di-electric grease before reassembling the connectors. Might help. SOP for me. Always have a tube laying around.
Anything is better than a new brain box.
/ Bad news big repair #240
Need to be careful with that use. Electronics prefer pure sine wave power that a cheapo 200 buck genny cannot provide. I have a small (2000 watt) inverter myself. Runs anything electronic flawlessly including the computer. Honda, Champion and a few others are available and very portable.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
(INOP) BROCE BW260 SWEEPER (A62129)
(INOP) BROCE BW260...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2019 F150 (A61306)
2019 F150 (A61306)
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
