/ has any GC series owner ever tried moving lift links back an inch on lift arms to gain lift height?
#1
Dmacleo
- Joined
- Sep 11, 2020
- Messages
- 1,980
- Location
- Etna, Maine
- Tractor
- 2010 MF GC2400 Owner, 2012 MF1532 User
this prob would only apply to gc series scut due to design but looking at stuff today I realized if I move my lift link rearward 1.5 inches or so (and weld the old pin hole for strength) I gain almost 3.5" ( angles/physics/pure friggin magic) lift at the end of the arm.
I already have more than enough down travel for any implement I use and even if I did this (I did some mock tests) I can still set my reese adapter on titan quick hitch right on the ground.
I had been thinking about this even before I swapped out the pats hitches for the titan and lost 2-3" (depends on implement) total lift height at implement end.
I did look to see if I could attach the titan hitch ONTO the pats hitches but...full down position looks like it would crush latches so NOPE!!! LOL
full up I could make work by slight cut on bottom gusset but the the latch interference issue that stopped me.
still, nice to back up to 435lbs 5ft box scraper and drive off w/o getting off tractor.
tiller is all wrapped up for winter so not tested yet but expect same results.
reason I am interested in extra lift height is I do bunch of trailer movements with different vehicles on same trailer.
the 2011 chevy 2500HD with the bm 12" adjustable hitch I can easily set to no sharp ramp angle.
my 2011 mercury marquis....not so much even with air bags at 45psi LOL
hate having to raise chain on tiller rear guard to offload.
with no quick hitch had to in order to back off when using car, with pats (due to way the implement pins sit higher due to pats hitch CONTINUING the lift arm length 3") didn't have to.
with this titan hitch will need to.
