Branson 4820ch actual height with cab and ag tires
   / Branson 4820ch actual height with cab and ag tires #1
Jjohnson9989
Branson 5520ch
   / Branson 4820ch actual height with cab and ag tires #2
You should be able to google the specs and get that info.
   / Branson 4820ch actual height with cab and ag tires #4
I could give you an exact measurement on my cabbed 3725, but it may be slightly different than a cabbed 20 series.
Off the top of my head, I'm thinking it was right at 7 feet.
It will go in my garage attached to my house.
Yes that would be awesome. Appears to be same cab
   / Branson 4820ch actual height with cab and ag tires #6
My cab is 94" to the highest point on the cab.
My garage door (in the picture) has a 97" opening.
This is on a tractor with R4 tires, not R1 Ag tires. Just wanted to be clear on that.
   / Branson 4820ch actual height with cab and ag tires #7
I have a TYM T574 and I believe it is pretty much the same as the Branson 5520.The height of my T574 HST cab tractor is 99.6 inches according to the owners manual.
Hope this helps.
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
JOHN DEERE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN DEERE 1000...
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
2023 FORD F-250 (A58214)
2023 FORD F-250...
New/Unused Agrotk Wood Splitter (A57453)
New/Unused Agrotk...
20" X 24" ROLLING METAL CART (A58374)
20" X 24" ROLLING...
