Post pictures of your shop crane
   / Post pictures of your shop crane #1
Renze
Super Member
the Steernbos (Holland)
Zetor 3011, Zetor 5718
I have a 500kg Hitachi chain hoist on a beam in my shop, but my friend decided it needs a trolley before he helps me rebuild a tractor 😉
The used beam is flame straightened, and this week it will go under the rafters.
I was wondering, how does everybody have their umbilical power supply to the hoist: with a sliding door rail system, or is a steel cable with chain links as sliders, satisfactory ?
   / Post pictures of your shop crane #2
I have done it both ways over the years. First one (done 30+ years ago in my dad's shop) we zip tied 2" rings to the power cable and then the rings slid on a steel wire. Worked fine. When I did my own about 10 years ago, I used barn door rail with little wheel trolleys that had a cast loop on them, and zip tied the cable to the loop. I think that was overkill (and much more expensive) but it sure slid nice and smooth.
I already have a roll of leftover new steel wire, which was too thick for the overhead door. The ones with wheels on a steel wire, at the company i did my apprenticeship, never worked right, they allways jammed.
   / Post pictures of your shop crane #5
I have a portable that I use whenever the time calls for it but, it isn't as convenient as what you guys are doing. Nice job!
Got a pole at the wooden wall to support that end, and have the stuff hanging. My mates brother in law checked yesterday, and said he wanted it down at ground level to replace some burnt wiring before hooking up the electrical cord...
I ordered cast aluminium trolleys with a nylon wheel in them to run the umbilical cord on the steel cable, we'll see how that works...
   / Post pictures of your shop crane #7
Have several 2” receivers in shop to mount crane or other tools. Attach to rolling welding bench to self load or for mobile use. Base modified to support multiple jacks for support.
   / Post pictures of your shop crane #8
It ain't much but it works for me. A couple 2x4's with some grommets and a 3 to 1 pulley.
   / Post pictures of your shop crane #9
We have A frames with casters and two trolleys with a hoist on each. So two hoists per A frame. Hoists Are 14' tall.
Got the cable suspended on the pulleys, but it jams. Next thing im going to do is order some swivels so which ever method i choose to fixate the cable in the eyelet, it wont cause twist which jams the pulleys....
549 (A52708)
549 (A52708)
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
PALLET OF LIGHT BULBS & PIPE VICE STAND (A52708)
PALLET OF LIGHT...
1734 (A58374)
1734 (A58374)
SCALES & PEA (A58374)
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
