Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 26,373
- Location
- The Last Red State in the Northeast
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Stop on down.I would look at the relays in the existing system. With two relays does each relay provide power to half the glow plugs.
Or does one do preheat and one do after start heat.
You may wish to ohm out the connections to the relay coil to see if one goes to ground constantly or if they are having constant power applied and switching the ground through the ecm.
If they are standard 5 pin relays get some #22 wire and slip it in the relay coil contacts to see if the relays are being activated. You can look for voltage to be applied to either contact of the relay coil if you have voltage on both pins you will know they are switching the ground with the ecm.
Once you know what they where attempting to do run a wire to the existing relay through a switch to either power or provide a ground.
That should allow you to control the glo plugs and get her started much easier and smoother.
I can bring beer and great take out food.
Had my ass up in that engine compartment enough….
