Vented Axle Dipstick for the John Deere 3/4 Series
   / Vented Axle Dipstick for the John Deere 3/4 Series #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
Introducing the VDS from Otis Innovation, distributed by BoltOnHooks LLC. Our vented dipstick developed for MFWD (Mechanical Front Wheel Drive) front ends allow axle housings to breathe bi-directionally, preventing over-pressurization and vacuum scenarios caused by factory sealed housings or one-way relief valves made by other manufacturers including the OEM option. Order yours today and keep your tractor breathing!
Features:
  • Provides protection from axle housing pressurization/vacuum, preventing potential hub seal failure, oil leaks, costly repairs and down time.
  • Precision machined aluminum dipstick and fittings replace OEM components
  • High-mounted, inverted vent and enclosed filtration system offer maximum protection from water, dust and debris
  • Extruded dipstick boss allows for tool-less removal or accepts ¾” (19mm) wrench
  • Beaded hose adapter allows for quick removal of vent hose for oil level checks
  • Hose length from 2” to 42” depending on tractor model and/or user preference
  • No moving parts
  • All associated hardware for complete installation included
  • Designed and made in USA
Kit Includes:
  • Replacement machined aluminum dipstick with appropriate level indicator
  • Tygon A-60-G vent tubing
  • Precision machined hose adapter and vent assembly
  • All associated o-rings
  • Dust filter
  • Cable Ties
  • Adhesive-back cable tie mounts and screws for additional versatility
  • Spring clamps
  • Detailed Instructions
Fitment:
VDS-JD-3 –
Replaces John Deere factory dipstick AM127176 for use in the following tractors:*
Models for the John Deere 1 and 2 series coming soon!
3120372042102036R3033R3039R4044R4052M HD
3203410543002038R3036E3045R4049M4052R
3320412043203025E3038E3046R4049R4066M HD
352042002032R**3032E3038R4044M4052M4066R
Axle Vents - BoltOnHooks LLC
Axle vents, axle vent plug, vented plug, vented axle plug
www.boltonhooks.com
www.boltonhooks.com
   / Vented Axle Dipstick for the John Deere 3/4 Series #2
That's awesome!
It's about time this became available
   / Vented Axle Dipstick for the John Deere 3/4 Series #3
Think I'd just drill a small hole in the OEM fill plug and be done with it. Guess Kubota already covered that issue, both my M's have vent hoses on the front axles.
   / Vented Axle Dipstick for the John Deere 3/4 Series #4
Sounds like a good product.
I leave the dip stick loose on my JD 4300. Works well, and thanks to TBN for pointing out the problem of not having the front wheel drive vented. No seals blown out so far.
   / Vented Axle Dipstick for the John Deere 3/4 Series #6
Just works for me. Never wiggled out and does the venting job at no additional cost.
If I were making river crossings, then would not be good.
I do a lot of moving through brush in the woods, and having another hose to catch on brush and rip off might not be the best for me.
Your design is likely much better answer for the best venting.
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
1990 KME (A53424)
1990 KME (A53424)
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
flooring (A55758)
flooring (A55758)
