Heat a basement?
/ Heat a basement? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I grew up in a house with a basement, near Chicago. Fast forward 50 years, after living in houses with NO basement (crawl space - then on a slab for 30 years) I have now moved to a 100 year old farm house in rural Iowa. Winter is cold in both locales.
This house has a basement, used only for laundry and storage. LP furnace (brand new) and electric hot water heater are down there as well. The walls are 1/2 cinder block under the newer single level, 1/2 field stone under the original 2 story.
My question is this: should I open up the single duct outlet to heat the basement as much as that will, or keep it closed - sending all the heat to the occupied area?
/ Heat a basement? #2
Where does the furnace get its supply air (air from the room to the furnace)?
You have an LP gas furnace in the basement? Is it a daylight basement?
/ Heat a basement?
The furnace is a brand new Trane high efficiency with the PVC pipes for combustion air inlet and exhaust outlet. The cold air returns are in the living room and first floor bedroom. What is a daylight basement? I have one window in a window well...
/ Heat a basement? #4
Would be lot extra work have you consider 2" styrofoam...blue board as some call it...outside block wall?
/ Heat a basement? #5
You posed a question as to if you should heat your basement. Is there a reason you are thinking of heating your basement? My office is in my basement so I heat it. If I didn't spend a fair amount of time in my basement, I wouldn't heat it.
/ Heat a basement?
There is 1" pink foam board on the outside of the cinder block first floor walls. I had that added when they dug down and installed/replaced the plugged/bad foundation drain system. The reason for my inquiry really is only if it helps the heated living area feel any warmer, is more effiecent for some reason or prevent mold down there (since it'd be warmer/drier). I'll say one thing - the basement is DRY since the foundation drain was fixed, and dirt landscaped to slope away from the house. Oh, functioning gutters helped too...
/ Heat a basement? #7
As U know heat rises, so heating the basement would result in warm floors for U to walk on.
Assuming the basement is insulated I'd suspect the additional heat costs would be minimal.
Perhaps adding some insulation to that one window would be beneficial (like a Styrofoam panel).
/ Heat a basement? #8
Obviously the warm air, if you have some in the basement, will rise and to some degree, make the floor above perhaps feel a bit warmer....but I doubt that a single duct would really have that much of an impact. Not having mold is always a good thing....and a humidity check would give you a good indication of where you sit in regards to that.
/ Heat a basement? #9
Since your basement is dry you shouldn't have a mold/mildew problem. My only concern with heat would be with freezing pipes, expecially if they are on outside walls. How cold does it get in the basement?
Another concern is Radon. Have you had a Radon test in the basement? From what I recall dealing with selling my father's house. Radon can build up in a basement. If you vent the basement, or turn the air over in the basement, it doesn't build up as much. Anyhow, I'd get a radon test kit if it was never done.
/ Heat a basement?
There is a dehumidifier down there. It ran NONSTOP before the foundation drain was fixed, and the place was always damp. Now, it keeps it around 40% and even shuts off when not needed.
/ Heat a basement?
Radon is all over Iowa, I've read. No test, no system (at least yet...). Needed? Yes, I'm sure.
/ Heat a basement? #12
A furnace typically runs most efficiently when all vents are open. I used to use a small fan vs any heater to de-stratify basement air, (7" IIRC) set it on the floor tilted up ~45 deg, and ran it 24/7. It made the basement seem less cold and improved circulation.
I used to block basement HVAC outlets in the Winter but no longer do having learned better. A dehumidifier replaced the fan(s) within a year and exhausts straight up, pulling cooler air off the floor and circulating.
"When it's done right." (y) In this case a trifecta. btw, is there room downstairs to set up the train, or would you build a bigger layout from scratch? ;) Asking for a friend. :rolleyes:
/ Heat a basement? #13
I heat mine cuz i use it. Physics says if u dont use it, dont heat it. It will cost more to heat the extra space.
  • Good Post
Reactions: JJT
/ Heat a basement? #14
vent in the basement may not heat much any way. Depends on the size of the area being heated and the size of the vent.
The thermostat is most likely located in the house (living area) so it will sense the temp in the living area, and most likely shut off the furnace before the basement ever warms up much
/ Heat a basement? #15
Unless the division between the basement and the rest of the house is insulated you're heating the basement whether you want to or not. What determines the heat loss for a building is the insulation level and area of the exterior. Turning off a vent in the basement doesn't change either of those. With the basement unheated the first floor loses more heat through the floor and total energy use is about the same.
Keep in mind that once you get above the temperature needed to keep the pipes from freezing heat is only there for comfort. Do what makes you comfortable.
/ Heat a basement? #16
Is the basement ceiling insulated ?
/ Heat a basement? #17
I've been here 40 years. Only time I ever heated the basement - we had -20F weather for three straight days. Put a small electric heater in the basement to protect the water pipes.
Basement is just used for storage. Usually will stay right around 55F - except in the very coldest weather. Without any heat - coldest I've ever seen in my basement - 38F.
I would not heat your basement - unless you have planned activities down there.
Hang a big dial thermometer down there. Gives you an idea what temps you are actually dealing with.
/ Heat a basement? #18
As many have said, it depends on your intended use. Back home in SD, many, if not most, basements are at least partially used as living space. Humidity control is more important than heating, but in those types of climates at least some heat will be good. My folks had an electric fireplace so it was warmer as needed. I'd open the vent.
/ Heat a basement? #19
The foundation drain is needed to prevent water pressure which places stress on the walls and floor leading to cracks and water infiltration.
The dehumidifier serves a somewhat different purpose. My house in Iowa has a basement with a very effective drainage system. Never the less a dehumidifier is needed in the summer months to keep the basement air dry preventing mold. In the winter basement humidity is not a problem no dehumidifier needed.
I do not heat or cool my basement because I have no living spaces there, just occasional use workshop, etc.
/ Heat a basement? #20
I heat our basement when it’s real cold even if we don’t use it. It heats the floors, making the whole house warmer. I installed a pellet stove in the basement and it doesn’t take much to heat it because it’s insulated and finished.
2024 Keystone RV Retreat Camper, VIN # 4YDTHRT28RW260127 (A61165)
2024 Keystone RV...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2006 Volvo VNM S/A Day Cab Truck Tractor (A61568)
2006 Volvo VNM S/A...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
UNUSED JCT 84" SNOW PUSHER (A62131)
UNUSED JCT 84"...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
