What do I look for in used tractor?
   / What do I look for in used tractor? #1
Nick Danger
Member
You can't get there from here
58 560 D
Looking at some B3350HSDC units and am wondering which years to stay away from as far as any tier 3 or tier 4 issues. From what little I read, the early years were problematic...although to what degree, I don't know...
Besides AG tires, a bucket and cab w/ heater, what should I be looking for as far as extras?
Pricing sure seems to be all over the place, like 15k swing for similar models...is this normal? Is there a way to find out how much the unit sold for new?
thx!
   / What do I look for in used tractor? #2
In general, now is not the time to buy used unless you are only interested in models or features that are no longer in production. Due to limited availability of new equipment, used prices are approaching new ones. Personally, I would be wary of a low priced used right now unless I knew the seller pretty well. To me, that screams 'problem'. I know there may be exceptions, just my admittedly cautious approach.
   / What do I look for in used tractor? #3
thx!
I personally would not consider ANY of the B3350's. While there were several computer updates, I don't believe Kubota ever resolved the emissions issues on that model, and it was discontinued.
Some owners never had a problem, but a little reading will reveal that this model was never made reliable for a large number of owners. I was tractor shopping in 2016 and the B3350 was immediately off my list.
   / What do I look for in used tractor? #4
Tractor Data dot Com is a good place to find model info on the major brands. They typically list original price but lack prices for accessories. And the price is usually for the beginning model year. If you want to compare prices, Tractor House dot Com typically has dealer and auction listings for models you search for. You can also sequence the list nearest your zip code.
the B3350 was made thru 2019...So, do you think it's the 4 cyl configuration vs the 3 cyl? Or is it specific to the 3350 series? If so, then can anyone steer me to a comparable model?
I was on their site looking at the L series, but no cabs...so now looking at the LX series...
   / What do I look for in used tractor? #6
Are you keeping your 560 and attachments? That's a heavy machine so I would think you might want something a bit bigger - like the Kubota L3560-4060 size with a Cab.
I agree with the others stay away from the 3350 series.
   / What do I look for in used tractor? #7
It was limited to the B3350 and possibly the ZD1511 mower. Both were 4 cylinders, but I believe the issue was a computer controlled manually injected engine. I could be wrong about that though.
If the LX series was in production when I bought I would have gone with the LX3310. I ended up in an L4060 HSTC, which is a few steps up from the LX3310. Great tractor.
My plan is to sell the 560 as I am looking to get something smaller...as I get older, the 560 seems to be getting taller...While I do love its fortitude, my uses are rotary mowing the 4 acre pasture, blow snow and grade my 2/10 mile long drive with an addl circle and between buildings, load manure for the neighbor and haul off the occasional tree...yes, it does make small work of everything, but a technology upgrade would be nice
With a limited number of shopping days, I'm also looking to the future that the wife can handle...the 560? I won't let her touch it...hell, I can barely keep it tame...lol
On a side note, what CAT size are on the L's? Everything for the 560 is CAT 2 (I believe) so not sure if I go to a CAT 1, will it be enough to handle...
thanks for the insite!
Great! This is the information I'm looking for...In conversation about a 3350 with a guy in Tennessee. He mentioned something about this unit's emissions in colder climates. So I did ask him specifically if it was tied to the unit and Tier 4. Hoping to get some more clarification from him as well...
Thanks!
   / What do I look for in used tractor? #10
thx!
Do not touch a B3350 with a 10 foot pole. It is one of the few Kubota tractors that was a near lemon. The Tier 4 emissions in this small of a tractor was not well designed in this first iteration, and it showed. Multiple CSBs, dealers confused and in many cases ended up refusing to sell that model tractor outright because of the headache of troubleshooting emissions issues.
Kubota discontinued the model and came out with the LX3310 in 2019-2020, which is basically the same machine but with updated engine/emissions system. I have not heard of any issues with the LX3310. The LX series is the new B50 series. LX2610 is the old B2650. LX3310 is the old B3350. Identical frames, mostly the same features. A few incremental updates for the updated models.
Avoid the B3350.
   / What do I look for in used tractor? #11
Look for shedded.
Look for an old guy who bought it new and put 88hrs, and 6 oil changes through it in 5 years.
That approach has worked for me. The 75hp and below units 50/50 end up being yard decorations. I do 300hrs a year even at that pace it will be a decade, and electric tractor time before I wear out my “used” tractor.
Avoid the B3350.
thanks!
Look for shedded.
Old guy? Hmmm, that could be me...lol
THanks for the advice!
   / What do I look for in used tractor? #14
Thanks!
Hopefully you are not still considering the Tennessee B3350, but if you are, consider this :
There are plenty of B3350's that were specifically in warm climates that had problems and practically lived at the dealership. Kubota tried real hard to cram a BS narrative down owner's throats claiming cold weather and operator error by running them at too low RPMs.
   / What do I look for in used tractor? #15
The Kubota L5460HST (54HP) and up from there and are Cat 1 or Cat II 3PT compatible so you can use your existing implements which in your case is very important.
You should also consider a front grapple for trees and manure loading - but a set of tines on the loader is good for manure/straw mix. Then maybe a front plow vs the blower - but for 2/10 mile drive - you can do that with the loader/back blade.
All depends on where you live - do you get 120" snow. and your use cases.
   / What do I look for in used tractor? #16
Not that I want one,but Kubota is offering a lifetime warranty on the emission system?
Will they still spend a lot of time in the shop?
Good Luck!
   / What do I look for in used tractor? #17
The MX series also has a cat 2 hitch.
Nope, he told me to steer clear of them...thx!
Problem being, the higher the model number, the higher the cost, then it becomes "does the cost warrant the upgrade"... to me, over 20k is a push, but for the right unit, I would go higher...since I don't have an operation to depreciate, I just can't justify over 30k...
I'd also like to downsize as the 560 is a beast size wise...a good 22' with bucket and blower...
Tines / grapple are good ideas...
Live in central MN, so yes, snow can be an issue as my driveway runs E/W with E exit and open pasture north side...years back we had a snowstorm in January. It left a couple of feet on the driveway and at the end where it dips down about 4' to the highway, it was 6' deep. I had a blade and bucket. I was on that thing for 9 hours in subzero temps with a 20 mph NW wind...needless to say, the following summer I purchased a blower and put a cab on. I also started to put up a 200' snow fence every year which minimizes the amount of snow at the end.
my neighbor has an 18hp with front blower that does an amazing job (depending upon depth and wetness...I'm assuming there are blowers for the high end of the cat 1 that would do even better...
   / What do I look for in used tractor? #20
If the tires hold air. Start engine and pull lift handle up. If the lift raises, I'm ready to deal...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2012 International 4300 Reefer Truck (A56438)
2012 International...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
1979 Ford H-48 Excavator (A56438)
1979 Ford H-48...
