Leinbach Carryall
   / Leinbach Carryall #11
If the wood on it is good, $80 is good for both parties; $100 if the seller is a friend, $60 would be a bargain, IMO.
If the wood needs to be replaced, $60...
   / Leinbach Carryall #12
The frame appears to be built of a heavier metal stock than the current TSC branded model.
   / Leinbach Carryall #13
I have one. heavy angle tray, heavy angle top and back. Side pockets for stakes. They made good stuff.
   / Leinbach Carryall #15
I'm not liking that 6 inch spacing out from the lift pins.
With the TSC carry all frame, outfitted with a 42 inch wide 1X6 cedar headboard and deck with very low sides, The B7200 can BARELY lift a capacity load of stone and dirt. 'Frequently can not lift a full load of hardwood rounds to carry them while splitting firewood.
The quick hitch would only make it worse.
   / Leinbach Carryall #16
I have one identical. Not quick hitch compatible as-is, but easy to fix.
To make it work, I bought some long-thread pins and spaced them outwards about an inch using washers. For the top hook, I cut a hole about where the "nb" is to allow the hook tip to pass through. Works fine now.
I don't have boards on mine. I'll use a pallet if needed. I use them along with clamp-on bucket forks to carry twice as much at one time, or to carry something too heavy for the forks to lift.
Bruce
   / Leinbach Carryall #17
The photo from hslogger is different than the OP's and mine. Ours has the angle braces forward of the uprights, not behind them.
Bruce
   / Leinbach Carryall #18
Bruce
Mine does too:
As you said, I also used washers to move the pins out a bit to better match the width of my other implements.
I use the hooks and ropes to secure large loads of firewood when carrying it out of the woods.
   / Leinbach Carryall
Well I drug the old carryall home today, bought it for $50. I stripped off the old rotten wooden deck, now to get out the grinder and find a welder to make it quick hitch ready. I’ll top it off with new fresh cut oak 2x12’s off my band I’ll and some LS safety blue paint and I should be good to go!
   / Leinbach Carryall #20
More than good to go by the sounds !
gg
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
CATERPILLAR...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
Bowie ISD- (A55973)
Bowie ISD- (A55973)
