Return hose adapter for post driver
/ Return hose adapter for post driver #1
WRX
Member
Cub Cadet 8354SS
I have a Shaver post driver. The 3/4" hydraulic return hose is supposed to go into the filler neck due to the volume of fluid expelled on the down stroke rapidly. Does anyone know which adapter will work on a Kioti. The goal is to remove the screw-in filler plug with the goose neck breather while using the post driver. I will then connect my return line to the filler neck. Someone said you can just stick the hose down in the filler neck and secure it with zip ties, but I'd like to keep dirt from getting in there unnecessarily. Any thoughts? The tech at Shaver did not know if one is available.
/ Return hose adapter for post driver #2
Something around a 25 x ? thread to a 19mm barb fitting?
Take plug to a tractor/hydraulic parts house and size one up. Heck, go to your local hardware store and by a grey PVC 1"MNPT x 3/4" barb and gently force it into that hole. There's no high pressure, just volume.
My LK3054 has basically the same set up to dump fluid back into the rear housing. It had rear remotes and a back hoe connections.
Patrick
/ Return hose adapter for post driver #3
Where can I get one of those gooseneck vents? Something like that is what I need for the differential fill plug.
I guess the first thing is to figure out the thread diameter and pitch of the plug. I presume all these fasteners are metric. Is that correct?
Not sure if you can get one for the diff. Isn't that a much smaller plug? This plug is pretty standard for the trans filler on lots of Kioti tractors.
/ Return hose adapter for post driver #6
Take you fill plug to a machine shop, have them determine the thread pitch and turn you an aluminum dummy plug internally threaded to accept a hose barb fitting and connect your return line to that. In my case with my Shaver, I used the return fitting on the pto rear case to return the fluid on my M9 Kubota.
I put on a Tee with a QD fitting and a QD fitting on the hose. If you go the fill plug route (like I suggest above), you'll need to keep the hose end in a plastic bag with a zip tie on it when not in use to keep the dirt off the fitting and the hose end.
/ Return hose adapter for post driver #8
Just make doubly sure your fluid level is full when using the Shaver. It takes (and returns) a lot of fluid when operating.
/ Return hose adapter for post driver #9
I was very surprised to learn the threaded fill cap on a Kubota L4701 matched the diameter and pitch of 1" NPT, only the plug thread isn't tapered. Don't overlook the possibility that a trip to the local hardware store and a few bucks worth of simple fittings will fix you up.
I wondered, so I am stocking up on fluid. When you stop using the driver, do you wind up with an overfull transmission case?
/ Return hose adapter for post driver #11
No. The amount of oil in a fully extended Shaver cylinder isn't all that much. The cylinder bore is about 1-1/4"- 1-1/2".
Flow through the driver itself is continuous, not intermittent except for the cyclical demand of filling the pounder cylinder.
Your FEL lift circuit probably draws more oil from your system at full lift than the post driver.
/ Return hose adapter for post driver #12
Check your fluid level when the Shaver driver is all the way up, as the previous poster said you will probably have a constant flow through the driver valve and it will drop the fluid level some but not much. When I got a new tractor last year I drained the cylinder on my driver and replaced some seals before hooking it to the new one, I don't remember how much fluid it took to fill the cylinder but I don't remember having to add too much to the tractor.
/ Return hose adapter for post driver #13
Ask your dealer for the Return Line Kit that came with the older KB24XX Series Backhoes for your tractor model. It included the filler port adapter, and elbow, and a Female 1/2" Quick Coupler, and the breather tube. Exactly what you need to plug your return directly to tank.
/ Return hose adapter for post driver #14
I got mine from my kioti dealer. Its the same as they use for backhoes.
/ Return hose adapter for post driver #16
I don't have a Kioti I have a Mahindra but you just gave me an idea.
/ Return hose adapter for post driver #17
Looks like NPT threads. Take to th hardware/farm store and see if you can match it up with a threaded hose barb.
/ Return hose adapter for post driver #18
Most of the KIOTI Tractors are Straight Thread O-Ring Boss on the fill tube.
Hope this helps
Shaver called back and said I need a sm-67-r adapter for my tractor. I can't find a picture online but they are $55 at a distributor online.
Then my awesome Kioti dealer hooked me up by fabricating an adapter with a quick connect and moving my vent to an existing unused tap, making connecting a breeze and keeping dirt out of the system. Jordan at Paige Tractors has been a pleasure to deal with on the purchase of a new tractor and getting it set up for what I plan to do with it.
View attachment 721434View attachment 721435View attachment 721436
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
PORTA POTTY (A68842)
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A69167)
2006 CHEVROLET...
