Changing coolant yearly or lack thereof.
   / Changing coolant yearly or lack thereof. #91
.... in this case is it really that important? water freezes at 0C and -30F and -30C are roughly the same.
Probably not
-40C = -40F.
50/50 mix on antifreeze is supposed to be good to -34F (which is the record low here) which is about -36C, so pretty close. All I really care about is "is it good or do I need to change it"
   / Changing coolant yearly or lack thereof. #92
Nope, probably not. Just a little bit convenient. I do like the feature that tells the precentage of antifreeze and water. But that could be looked up on a %/Temp table.
   / Changing coolant yearly or lack thereof. #93
What do you guys do with your old antifreeze? My transfer station no longer takes it
   / Changing coolant yearly or lack thereof. #96
Isn't it hazmat that they have to pay to dispose of?
Unsure they pay to get rid of it or if they are paid for it. I know the shop gets paid for used oil.
   / Changing coolant yearly or lack thereof. #97
The place where I take my oil, the county dump, collects it separate. Antifreeze can be recycled.
   / Changing coolant yearly or lack thereof. #98
Ethylene glycol is great herbicide. Use responsibly. It also kills wood rot. Wood has a great affinity for glycol. One of the more expensive ingredients in paint.
Used antifreeze, boric acid and 20 mule team borax to make our own BoraCare to treat our log cabin and barn Timbers from termites. Glycol will carry the borate to the center of the log. Bugs and termites will never build immunity to borate. Glycol kills fungi.
So used ethylene glycol has many uses on the farm. Most auto parts will take it too.
   / Changing coolant yearly or lack thereof. #99
Plan to change out the coolant next year on the Isuzu diesel generator, its 10th year.
Not around here, they won't. Didn't know about all those other uses though, thx!
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
CUMMINS ONAN SD 2000 GENERATOR (A55745)
CUMMINS ONAN SD...
Mini Excavator (A55787)
Mini Excavator...
2014 MACK CHU613 DAYCAB (A55745)
2014 MACK CHU613...
