Back up camera
/ Back up camera #1
Raul5452
Corpus Christi Texas
John Deere 970, Kubota M7060
Hello all, I have a Kubota m7060 hd 12.
I do alot of tractor mowing for customers. Vacant lots , pastures and dirt work. I do all my work within a 5 mile radius and it keeps me busy. I'm tired of backing up to far and hitting objects with the shredder tailwheel or doing dirt work / spreading reclaim asphalt and coming close to backing up to some fool that sees me backing up but still pulls up right behind me. Hence the need for a BACK UP CAMERA. Any recommendations from some of you that have already been down this road ? Thank you in advance. I'm considering a wireless camera for the sake of less wiring.
/ Back up camera #2
If it's going to be fixed permanently it will probably be better to go with wired.
I use Wyze cameras for occasional backup cameras, a camera, powerbank, and mobile hotspot all fit in a Ziploc bag and its easy to hook up to whatever I want.
But if you want reliability run a wired cam.
/ Back up camera #3
Check the link below. Many of us have bought these and they work fairly decent. Only problems I've had in 7 years is had to replace a camera 1X and replace the monitor 1X.
/ Back up camera #4
Been there , done that.
Bought a el cheepo on the net for $50. ish.
No problems, even in Quebec's coldest weather.
OK, built in 'guide lines' (for back up) don't depict your actual situation but sure provides a relative imaging.
But then I did mount my camera high up under my rear cab overhang so that snow would not interfere.
\Go for it! Your neck will thank you!
/ Back up camera #5
I use my go pro camera. I already had it and it works with my phone as the monitor. We also use it in the horse trailer and watch on a tablet in the car. Lots of mount accessories available for go pro and video quality is good.
/ Back up camera #6
I occasionally have a need for a backup camera and also to better see what I'm working on. Like you, I'm not a fan of wiring things so I made a portable wireless camera system powered by cordless tool batteries. I use strong magnets to hold them in place wherever they're needed.
Check out this thread on how it was done:
/ Back up camera
You are a very ingenious man Sir.
/ Back up camera
Gentlemen I cannot thank you enough for your input and sharing how you solved your ideas in accomplishing this problem. I'm anxious now to decide which way I will go because all of you had really good info. I love this forum. Great place to share ideas or help solve problems we all encounter sooner or later.👍
/ Back up camera #10
If you use it on a open station tractor, you may have to fabricate something to shade the screen.
/ Back up camera #11
I bought the Halo system. It ain't 50 bucks but I got 3 wireless cameras and 2 battery packs plus the monitor. I like the wireless because I can place a camera anywhere I need one. I use them mostly on the loader and forks for being able to see what I'm engaging. They are also nice for use with my trim saw since it's over the cab and out of sight a lot. Cameras aren't perfect and the sun affects them in different ways but for an overall view they are nice.
/ Back up camera
Thank you Sir . I do have an open station tractor with a canopy but it doesn't always block the sun. I will include that as I move forward with this project.
/ Back up camera #13
Also be aware of the "Field of View" of the camera:
2011 Ford Explorer (A64127)
2011 Ford Explorer...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
New Holland 3930 (A60462)
New Holland 3930...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2005 TerraGator 8104 (A63688)
2005 TerraGator...
