L3200 Rear Remote Valves
/ L3200 Rear Remote Valves #1
RobinM
Dorset, UK
Kubota L3200
I have a post driver for my L3200 and need to add rear remote valves for flow and return- I understand there was a kit available from Kubota, but don't think it is still available?
Any help where to get a kit or something similar would be greatly appreciated.
Cheers
Robin
/ L3200 Rear Remote Valves #2
summit hydraulics? they have a number of tractor specific as well as universal remote kits
/ L3200 Rear Remote Valves #4
I did not see the kit listed under L3200. Put it in as an L4701H tractor and go to Options at the bottom. There you will find the kit for auxiliary control valves. I wonder if that kit will also fit L3200, or there is another number for that kit. Don't know if that helps or not.
/ L3200 Rear Remote Valves #5
Ask your Kubota dealer, the kits are in the Kubota Wholegoods catalog. Back when I ordered in 2014, the parts I got were:
L7334 1st position and valve/hose kit
L7364 2nd Position stacking kit
L7354 Float detent valve for 2nd position
You can get other types of valves for position 2, as well as valves for position 3 if desired.
You can also rig up a DIY solution pretty easily, just need to tap into the power beyond circuit after the loader and before the 3-point hitch (same as a backhoe).
Thanks, I'll have a look
Thanks I'll see if my local dealer can get hold of these
(2) Firestone Tires (A65640)
(2) Firestone...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
