Front Tire Popped Off Bead
/ Front Tire Popped Off Bead #1
Frankenkubota
Elite Member
Carthage NC...Deep in the woods
Kubota MX 5800, SkidPro 4 in 1, Ratchet rake, SkidPro pallet forks
I was lifting the biggest stump yet and while slowly backing up I turned the steering wheel all the way and heard POP. Front left tire.
My first real job was at Art and Bills Enco gas station changing oil and plugs and tires etc etc. It was a "service station".
Sometimes when changing tires the new tire wouldn't seat on the wheel so you jacked it around and hugged it and fiddled and when none of that worked you got a hose that you would wrap around the tire, then fill the hose with air, compressing the tire, forcing it to seat.
I ain't got one of them so.....
I tried a small ratchet strap but too small.
Today i'm trying a bigger ratchet strap but if it doesn't work i will remove the tire and take it to a friends. He has an air tank that dumps a large amount of air at once, he says that works.
I have read about putting some starting fluid in and lighting that. I'm not quite ready for that yet but i like it!
I know i can take it to a tire shop but i like to fix stuff myself, if i can.
I'm gonna try the bigger ratchet strap and the air dump today. Any other suggestions?
thx
/ Front Tire Popped Off Bead #4
Jack it up make sure the seats are clean and use the ether. Way easier than the alternative.
it's jacked up....the seats are clean and lubed but
i'm a puss. if you were here i'd bring you a coffee and watch!
thx again!
/ Front Tire Popped Off Bead #6
Valve Core out to seat?
It's made the difference for me being able to blast more to seat...
/ Front Tire Popped Off Bead #7
^^^^^ That right there.
I also have a clamp-on filler air tip without the internal valve depressor. The more air flow the better chance of seating the tire. And the little 12v compressors just ain't goin' to do it. 😏
/ Front Tire Popped Off Bead #8
Remove the valve stem core. Works more gooder that way.
It works, just be careful. Of course, take the weight off the tire first. That's more of a 'field' repair. If you can get the tire off, take it to your buddy's or to a repair shop. More than likely, the tire shop will just grin and re-seat it for nothing
thx
In the future, when you know you're gonna put some serious weight/strain on the front end, make sure to put more air in the tires. I always have a battery powered inflator nearby. I usually forget, though
/ Front Tire Popped Off Bead #9
Mr. Fankenbota, I've got your same tractor size, and rolled my left front tire off also.
3 inch ratchet strap worked for me.
But just to be prepared...
Ya'll who are actually "blowing up" your tires...what are the detailed steps?
/ Front Tire Popped Off Bead #10
Step one. Be careful.
Step two. Spray carburetor fluid in tire.
Step three. Light a stick.
Step four. Be careful.
Step five. Touch flame near tire so she blows.
Step six. Make sure fire is out.
Step seven. Air up the tire.
Good luck!
/ Front Tire Popped Off Bead #11
Just borrow your neighbors bead blaster.
Many of the new approved "ethers" are not volitile enough to work reliably.
/ Front Tire Popped Off Bead #12
I did it with a mud tire when I was stuck in a swamp. I think it was a 44" tire.
Try to take as much weight off the tire as you can. Spray in the Starting Fluid light a piece of (something, paper, stick, whatever) toss it at the tire where it's busted and, most importantly, run. Or at least make sure your back is turned. It makes quite a little 'pop'.
I don't recommend it. Don't use too much spray. You can always use more but if you start out with too much..... It really does explode.
/ Front Tire Popped Off Bead #13
Mine recently did that. It was an adventure.
It took me this many ratchet straps, and I still had to remove the valve stem at first.
/ Front Tire Popped Off Bead #14
I've used ether exactly twice (and won't be doing it again).
The first time I jacked up the tractor, used small amounts of ether until I got the desired effect. I also wore gloves, helmet, and faceshield. Worked like a charm.
The second time was on a zero turn tire. Being now an expert, I sprayed enough ether on the first shot, didn't wear any safety gear, and got some serious burns on my thumb and hand. I still think back on that incident... What was I thinking? Not much apparently.
/ Front Tire Popped Off Bead #15
remove the core in the valve stem. airline quick connect directly on the stem (no chuck). max pressure from fully charged compressor. ratchet straps like above with tire seated (close to seated) in stem area. once you seat, loosen the ratchet straps, new core, use air chuck to bring to right pressure. Helps if the airline is as big as you got ... no 1/4 inch. 3/8 minimum 1/2 inch better.
/ Front Tire Popped Off Bead #16
/ Front Tire Popped Off Bead #17
When this happened to me, I didn't have a ratchet strap. I just wrapped a couple turns of rope around it, inserted a tire iron, and twisted it to tighten the tire enough to hold it against the bead. It works very well.
/ Front Tire Popped Off Bead #18
Had it happen as well, the front right tire. It was winter and too cold to mess with so the local tire guy did it. He told me to put a tube in it (but didn't have one in stock). Well I should have because that tire always seemed to leak just a little bit of air and a few years later off it came again. I thought since it was less than a month since I topped off the air I would be all set but nope. Now it has a tube and hasn't given me any problems in 7 years. The front left is air tight.
I think either the tire bead is slightly larger than normal or the wheel is slightly smaller on the front right. The problem isn't leaking air but the tire slightly slipping on the rim. As it slips it also looses air. Since the wheels do have a bead like a car wheel will have it doesn't take much for the bead to slip off rim.
/ Front Tire Popped Off Bead #19
That method works very well indeed. Spray some in opening between tire and rim. I spray some fluid on a stick. Light it and put near the tire and boom it is on there. Check pressure and usually back it off.
/ Front Tire Popped Off Bead #20
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
