Is a 6' box blade too much for a compact?
   / Is a 6' box blade too much for a compact? #22
For some reason my reply didn't post earlier.
A Mahindra 2638 weighs a little over 3000 pounds without a loader or operator. I have a 6' box blade that originally came with a MFWD Massey-Ferguson 1030L I used to have. That tractor was fairly similar to the OP's Mahindra, it weighed about 2900 pounds without the loader or me on it and had unloaded ag tires. I did have a loader on it though. The tires would spin if there was more than about 6" of gravel in the box.
I now have a 2WD Deere 5075E with loaded ag tires. It pulls that same box blade to overflowing without knowing it is back there.
I would suspect that the OP would at the least need to have filled ag tires if not a larger tractor to pull a 6' box blade well.
Not sure if your MF had 4 wheel drive. You are correct, HP is similar. Not sure if 3 cylinder vs. 4 makes a difference. My tires are loaded. I am also on a grade so maybe a 5' would be best. Thanks for the reply.
   / Is a 6' box blade too much for a compact? #24
That little Massey-Ferguson had mechanical front wheel drive (MFWD.) 4 wheel drive is what the giant center-articulated tractors like Deere 9Rs have.
3 vs 4 cylinders make no difference if the tractors the engines are mounted in are about the same size and weight and the engine power is similar.
   / Is a 6' box blade too much for a compact? #25
Why don't you ask a dealer if you can demo one so you will know?
   / Is a 6' box blade too much for a compact? #26
I’ve got a 5’ Frontier box blade that we use on our JD 2720. It’s ok for light grading, but a little too much if you’re filling the box and moving dirt. I definitely wouldn’t go bigger on that size compact. Works great on My JD 4066R, albeit a little small for that tractor…I could easily pull a 6’ BB with the 4066R.
   / Is a 6' box blade too much for a compact? #27
I am clearing land with a 2638 Mahindra. I would like a 6' box blade to further reduce the cost of having someone do the finish work.
Next year, I am thinking a smaller compact will maintain the drive and clear a tree on occasion. IF that puts 5-10k back in my pocket, then I will do so.
(if the economy holds, I am guessing I can pretty easily trade down with someone unhappy with a compact)
So, the question is, can a compact handle the 6' or should I temporarily live with a 5' blade.
Thanks for any advice.
Years ago I had a little 18 hp, 2wd Allis Chalmers. I had a 5' blade used with other tractors at the time and decided to use it to help a neighbor cover up a water line trench. It didn't have the weight nor traction to put the blade at a 45* angle and move the dirt back over the trench.
   / Is a 6' box blade too much for a compact? #28
Was your AC diesel or gasoline?
   / Is a 6' box blade too much for a compact? #29
I pull a Bush Hog RO 720 - roll over box blade - behind my Kubota M6040. With the ROBB on the 3-point, the tractor weighs 9900 pounds. This is a 6 foot implement.
I must be careful that I don't make an overly aggressive cut. With the power and weight of my tractor - I can still end up with all four wheels digging. And I'm no longer moving forward.
So ....... with a six foot box blade - start with a shallow cut - stay with a shallow cut.
With my Fit Rite hydraulic top link - controlling cut depth is a snap. I've found that a 4" deep cut works very well in my soil type.
   / Is a 6' box blade too much for a compact? #30
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
Utility Trailer (A52377)
Utility Trailer...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
2004 Freightliner FL70 Trash Truck, VIN # 1FVABTCS64HM47795 (A54865)
2004 Freightliner...
