What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,061
The show at night come from the lights or the AR? I’m getting ready to install some lights too.
   / What did you do on or to your LS Tractor today? #2,062
Both the lights & the AR's ;);)
   / What did you do on or to your LS Tractor today? #2,063
Loaded my MT 125 on a trailer and headed out to my son’s house. I removed two stumps, moved a railroad tie, dug a hole and buried a cement block, moved dirt and filled in some holes, dug up and moved some brush and small trees, and leveled an area for a shed. I didn’t even use a quarter tank of fuel. The borrowed trailer was a little over kill for the size of my tractor, but my Ram 1500 handled it well..
   / What did you do on or to your LS Tractor today? #2,064
Tried to move a rock that was stronger than the 3037 with the backhoe.....
   / What did you do on or to your LS Tractor today? #2,066
What are we looking at here? At first I thought that was the top of the 3 point hitch with the picture posted upside down but upon further looking apparently not.
   / What did you do on or to your LS Tractor today? #2,067
Wow! That is where the subframe bracket attaches? Strange that it would break off that part of the case.
   / What did you do on or to your LS Tractor today? #2,068
I believe this area, this is on my MT240HE
   / What did you do on or to your LS Tractor today? #2,069
That is exactly where it broke. Cleaned everything up with some gasoline dried it all out, little grinding, about 8 Muggy Weld rods, some 3/16 plate to reinforce everything, back in service and finish the hole in less than 24 hours.
   / What did you do on or to your LS Tractor today? #2,070
Expensive mistake !
Not really, I repaired it myself, about $60 worth of specialty rods. If you look really closely you can see where some of the casting is pretty darn thin. But then that's why this tractor is $10,000 less than a comparably equipped green or orange tractor.
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55314)
2025 Wacker Neuson...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2007 INTERNATIONAL 9200I DAYCAB (A55745)
2007 INTERNATIONAL...
(APPROX. 12) UNUSED FUTURE 4' X 8' PLASTIC MATS (A52706)
(APPROX. 12)...
