Can you dye hydraulic or gear oil? If so with what?
   / Can you dye hydraulic or gear oil? If so with what?
Thank you! I figured there was a solution I just had to ask!
   / Can you dye hydraulic or gear oil? If so with what? #13
I paint the lower section of the dipstick with Flat Black paint. When it's wet with oil, it's obvious
   / Can you dye hydraulic or gear oil? If so with what? #15
I too have problems seeing the oil on the stick, so what I do is take a clean white paper towel. Remove the stick and lightly place the tip flat on the towel. When you raise the stick the oil level will be indicated on the towel.
I usually just carefully lay the tip flat on a pant leg, or a glove. But I'm always wearing pants when I'm "tractoring" but not necessarily gloves.
   / Can you dye hydraulic or gear oil? If so with what? #16
Guys
My NAPA dealer sells me colored TDH oil. Befoare, it was clear oil.
I think it is better than to dye oil.
Bye
   / Can you dye hydraulic or gear oil? If so with what? #17
Twice walmart has broken my dipstick!
Some genius decided to make the pull section of the dip stick out of plastic. i do have plastic parts on my 1988 bmw that are still like new so, plastic has its place as long as it's not the cheapest chit you can find.
after a long wait wait, i broke the rules, i walked into the walmart work area and there was this tweaker with a power drill in his had ready to drill out the broken dip stick.
yes, he was a dip chit workin on a dip stick.
i pointed out to him that 1 bolt and an o ring holds the dipstick tube in place, shut the hood and left.
he assured my there was "some" oil in there.
Did I read that right? You take your BMW to WalMart for an oil change? I'm sorry but isn't that expecting a miracle?
   / Can you dye hydraulic or gear oil? If so with what? #19
ha ha
good point!
funny, walmart has a list of vehicles they will not work on.
BMW is one on that list so, even if i wanted to take it to walmart, they wouldn't do it.
I can do the oil on my 1988 BMW 325 convert with out jacking it up!
The broken dip sticks were both chrysler sebring convertibles.
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2011 Cadillac SRX (A50324)
2011 Cadillac SRX...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
