Will 10 Horsepower actually matter on the same size tractor?
   / Will 10 Horsepower actually matter on the same size tractor? #172
The Type 4 standard is new in the most recent version of the ISO spec in 2014. I haven't seen it on any machinery in the wild but it apparently is a standard. It even got a mention in my tractor's owner's manual in their "don't mix PTOs with different RPMs" warning page.
Here is a link to a full copy of the standards but it is not free to read: ISO 500-3:2014
   / Will 10 Horsepower actually matter on the same size tractor? #173
Here's some more to think about.
Say we have a compact tractor with a standard 6 spline, 1 3/8" diameter that is usually spun at 540 RPM. Many compact tractors have a PTO gear box which gives the ability to spin the PTO at different (higher) speeds while holding the engine RPM & therefore the engine HP constant.
The PTO output torque will vary with the PTO RPM selected. Ignoring internal friction, the PTO output torque will decline by exactly the amount that the PTO RPM is increased by the PTO transmission. That holds true as long as the engine is at the same RPM.
rScotty
   / Will 10 Horsepower actually matter on the same size tractor? #174
rScotty
Asian compact tractors often do have the ability to run the PTO at more than 540 RPM as outside of the US, the standard 1 3/8" 6 spline PTO can be run at 1000 RPM instead of 540 RPM. Often they have speeds of 540, 700-800, and 1000 RPM. In the US, this is not done, we use the 21 spline 1 3/8" shaft instead for the "little 1000" implements to avoid destroying a 540 RPM implement by running it at 1000 RPM. As an aside, this is one of the "legitimate" reasons Kubota cites for not allowing their Japanese domestic market tractors to be imported into the US.
The other thing to think about is that on some larger compacts and many utility tractors, there are faster PTO gears available but they are restricted to keeping the PTO at a regular speeds but reducing engine RPM for an "economy" PTO. A tractor running in economy PTO mode will make less torque vs. standard mode for the same PTO RPM as the engine is making less power.
   / Will 10 Horsepower actually matter on the same size tractor? #175
The formula is in my post, horsepower = (torque*RPM)/5252. Applying seventh-grade algebra, torque = (horsepower*5252)/RPM.
Thanks mo it makes sense now.
So just checking my math here: If you have a tractor that produces 30 PTO hp then it makes 291 ft lbs of torque correct?
   / Will 10 Horsepower actually matter on the same size tractor? #176
Except for those that aren't. Tractors larger than those primarily discussed here are usually rated using 1000rpm PTO's. Many of these only offer 1000 rpm PTO.
Fair point.
I guess no overlooked the 1000 rpm bigger stuff. Since most of the questions and this post I'm general is dealing with compacts or utility sized machines.
   / Will 10 Horsepower actually matter on the same size tractor? #177
If you insert "at the PTO" after 291 ft-lbs then yes that statement and math is correct.
   / Will 10 Horsepower actually matter on the same size tractor? #178
Hi all, I wont lie, I am totally new to the tractor world. Very familiar with cars and trucks, not so much on tractors. But, I have been reading articles, posts, and watching videos like crazy for the past 2 months learning what I can as we shop tractors.
Lets take the Kioti NX4510 and NX5510 for example. Both HST. Same basic tractor, 10 more HP. Otherwise between the 2, its larger (wider) tires, and a better 3 pt hitch, thats it I think.
So does 10 Hp matter, say your using a decent sized PTO Snowblower in what the town plows leave behind after a 12" snow fall, is that 10 Hp noticeable?
What about if your just pushing snow around with a pusher box, will the extra HP and TQ help?
Is there other benefits of more HP other than running the PTO?
Have you ever in your 35 or 40 Hp tractor, wished you had 45 or 50 Hp?
Curious to hear everyone's opinions, thank you!
Yes so I went out and bought one....keeping the smaller one and adding several more over the years. Come haying season I use all 4 I currently have. It did require 5 but my last purchase of the LS does the work 2 used to do.
   / Will 10 Horsepower actually matter on the same size tractor? #179
That's an unexpected statement as the LS is the smallest of all the tractors you have listed on your profile. Can you explain how this is true?
   / Will 10 Horsepower actually matter on the same size tractor? #180
My first tractor - 1982 Ford 1700 4WD at approximately 3000 pounds. In 2009 I upgraded. 2009 Kubota M6040 4WD at exactly 10,072 pounds. The weight is due to HD grapple - Rim Guard in the rears - HD Rhino rear blade.
Did I notice a difference. YES The increased weight gave worlds more traction. More than double the engine HP didn't hurt either. But I do believe the increased weight was the biggest factor.
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
golf cart (A55758)
golf cart (A55758)
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
