2610 H
/ 2610 H #11
On mine, the manual states 250 hours between engine and oil filter for the first one after the 50 hour service and then every 200 hours. The oil comes out just barely black and still in great shape.
100 hours seems kind of a waste to me, unless it wasn't done at the 50 hour service.
/ 2610 H
ptsg
It got its full 50 Hour service. My dealer got back to me with 200hr increments and I ask even the engine oil because I was just going to do that at every 50 and he said even the engine oil 200hr increments. Oil and filter is cheap I just might do it every spring because the tractor won't be used much over the winter and it is in an unheated shed so it will temp will be up and down depending on weather
/ 2610 H
Asteral​
That's what I was thinking but the dealer finally got back to me and said 200hr increments. As far as greasing zerks hey get down all the time
/ 2610 H
For the 2610H "10 Series" does anyone have a cross-reference chart for the filters. The fluids say Oil 80W-40 CGabove, Coolant ASTM D4985 Extended lift antifreeze, hydraulic OIL Texaco THD OIL 1893, Front axle 10w - 90. The front axle I have a bunch of but as far as the motor oil and hydraulic oils what's everyone using?
/ 2610 H #15
Picked up filters at my local dealer today for the 50Hr service on my 2610h. For reference, the manufacture p/n's are:
Engine oil: EA00003786A
Hyd oil: FE91050000B
Hydrostatic: TA00016986B
I stopped at my local NAPA (who're pretty decent parts people), and they couldn't cross reference any of the part numbers. They did note, however, that they're Mann Hummel filters, so they'll likely have them eventually.
Moak, I'm sure you meant 80w-90 oil for the front axle.
For the 2610H "10 Series" does anyone have a cross-reference chart for the filters. The fluids say Oil 10W-40 CGabove, Coolant ASTM D4985 Extended lift antifreeze, hydraulic OIL Texaco THD OIL 1893, Front axle 10w - 90. The front axle I have a bunch of but as far as the motor oil and hydraulic oils what's everyone using?
/ 2610 H
Thanks for the part number and yes we did just corrected it
/ 2610 H #17
For oils, the dealer refilled the trans/hyd with NAPA HD tractor hydraulic when they replaced the failed axle seal. And for engine oil, I'm using NAPA conventional 10W-40.
2014 FORD F-550 XL SUPER DUTY UTILITY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
Case skid steer wheels and tires (A61307)
Case skid steer...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
bad boy zero turn 72 (A56859)
bad boy zero turn...
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2016 Isuzu NPR-HD Box Truck (A60352)
2016 Isuzu NPR-HD...
