My attention span is so short that I...^^^^
I've seen those mentioned before. They might bear looking at. My chain has two consecutive LH teeth, so it's easy to keep track of where I started... as long as I remember to file those first.
I suck at freehanding, but these have made all the difference for me.
I prefer to sharpen over swapping chains, out in the field. Gives me a little more time to give myself and my saws a restMy main saw runs an 18" bar, so fairly quick work to sharpen.
I generally run the file across the teeth at least every other time that I fuel. I also only have an 18" chain, so it takes less time than a western saw.That’s what gassing up is for a drink for the saw and a drink of water for you then back to setting them up. Don’t feel bad I carry a lumber crayon too but I use to make qualities and sizes on the butts as I’m cutting.
I generally run the file across the teeth at least every other time that I fuel. I also only have an 18" chain, so it takes less time than a western saw.Unless I rocked the chain badly, t doesn't take much longer than it would take to swap it out.
The wheel I'm using has a rounded edge but it still produces a relatively flat face on the tooth. I will take another look at it since I have only used the grinder once. Maybe the grind is closer to hand filing than I remember. Memory is not what it used to be, lol.I don’t like hand filing the rakers. I usually just give them a quick bump on the bench grinder. Once the grinder marks wear off I give them another bump. About the square grind it sounds like you’re using the wrong wheel. Probably the one made to grind rakers.
You might be right and I will check to see how close it is to hand filing by holding my file to the tooth to see how it compares to the electric grind.Unless you've got some sort of funky sharpener that I can't picture, you should be able to get round-edge sharpening wheels for it, or dress the wheel you have to be round edge. It still won't exacty match what you get hand filing with a round file, but it's closer than square grinding.
I've got 2 of these. One for each chain size and use them all the time for hand filing. The only thing I don't like is that they don't do a good job of filing the rakers at the same time they file the teeth. I think they are meant to do both at once. I also think they don't take enough off the rakers and usually end up taking the flat file out of the holder and using it by itself, to take more off the rakers. The files they come with are very good quality though.I went through all sorts of filer guides and just before I was going to break down and get a grinder I ran across these:
https://www.stihlusa.com/products/chain-saws/filing-tools/2in1file/
Easy to pack out into the field. I also pack a marking crayon so I know when I've made a trip around the bar (makes it easier on tired eyes).
Can I ask why everywhere east of the Rockies runs such short bar? Doesn’t it bug your guys backs having to bend down all the time well limbing?
That's what I bought when I bought my Stihl back in March.I went through all sorts of filer guides and just before I was going to break down and get a grinder I ran across these:
I think you answered your own question, 6 Ricks unload the wood so you don't have to remove the trailer....Who the heck is Rick? And how do they all fit in that single cab? How many cords do you think? Do you have to unhook the trailer to dump?
