Yogi05
I found some kind of tack or small nail with the sawmill today too. Painless. Was over with in a flash and no discernible damage.
That brand new chainsaw wouldn't start again today. It's going back for a refund this time. 2 in a row is not a fluke saw, it's a
crap product.
Stopped on the way home and bought another new chain for my Homelite saw (that needs some convincing but at least
it starts).
Also bought one of the Oregon chain files with the clip thing that John_Mc referred to.
I didn't really want to buy another new chain but I don't have time to get proficient at sharpening, and tomorrow is tree cutting
day to replenish my beam stock. I likely need 7 trees to finish off my supply.
I'm hoping to get done by the end of the week then I can find a way to get the supply home and start tearing down my old wall.
Can't wait to see what's in store for me while doing that.
I've put the small logs aside for now. The ones I misjudged and can't get 6x6" out of. I can mill them to 4x4 for another task I
have on the books.
I have decided my log dogs are definitely a hindrance due to not holding well enough. A work around today was to jam part of a wll-rounded slab
under the log while using the dogs too. Worked well. I think I'll cut some wedges tomorrow from the small stock I have and see how that
works for me.
I mentioned I was consistently getting a 6x 6 1/4 while milling. I was changing things each time I did a cut today and I think I stumbled on
my problem. Pilot error. I changed the way I was marking and measuring my cuts and turned out perfect 6x6s after a while. Embarrassing, but
as you've all seen I'm willing to share the not so proud moments too
Can sawdust building up on the rubber of the drive wheels cause them to slip and burn the rubber a bit? I am getting a rubber burning smell
and a squeal once in a while and the blade won't power through stuff like it did a week ago. I can't hear the source over all the noise and I
don't see any smoke so I don't know if it's drive wheels or the belt off the clutch. There's very little rubber left on the wheels and they will
eventually have to be replaced I guess. All I could see that struck me as out of place was a layer of sawdust on the wheel rubber.
In the mean time I have to go a little slower at times.
That huge log I cut down the middle to get 2 cants from was beyond my, and the saws capability (too big and heavy for the dogs to hold safely)
and I set the second half aside till I get better at this stuff.
Glass half full - I'm getting there. 35 something logs done out of 56 needed. More than half way done and rolling right along.
But man, am I feeling it at the end of the day
But I've lost 4 lbs doing some physical stuff for a change instead of sitting for 10 hours
a day when I had a job
crap product.
it starts).
have on the books.
works for me.
