One step closer to zero emission power equipment
   / One step closer to zero emission power equipment #141
You all advocating for electric chain saws need to stop cutting brush for firewood and get into some real trees.....
   / One step closer to zero emission power equipment #142
I wish I had taken pictures of the tree I felled and broke down this spring with my little 16" battery chainsaw.
They cannot do everything, but they are much more capable than you think.
   / One step closer to zero emission power equipment #144
That's right...but, for what they're designed for, battery powered chainsaws do great...as do the pole saws
So, don't compare dropping a 24" diameter tree trunk with what most residential users need. That's foolish...
   / One step closer to zero emission power equipment #145
You all advocating for electric chain saws need to stop cutting brush for firewood and get into some real trees.....View attachment 717285
I think I’ve covered that before. Why use a 60cc saw with 24 inch bar to cut an 8” tree out of the road? Aside from it being overkill, that’s a lot of money to have tied up in a saw which rides around in the back of the truck and might get used once per month. I have a Poulan which cost me $100 new, that I bought for that purpose...
   / One step closer to zero emission power equipment #146
We had about a 100 yard long pile of debris left by the storm of May, 2018. My wife cleared the whole thing with a 12 inch Kobalt 40v chain saw. She wore out the first one there and then the next one when working on invasives up the slope. Kobalt went to pieces then with their chain saws; so, we went to a 12 inch Stihl for her to continue with the invasives work. She's still using it. Drinks bar oil like a drunk sailor but cuts well.
   / One step closer to zero emission power equipment #147
Reduce the fuel to match the air density and you get less power! No if and or buts. That’s Physics!
Physics? But the opposite happens.
Have you ever leaned out a carb, and what happens?
It runs faster, not slower...but there is a point where there is not enough fuel (oil is in the fuel) and the motor is starved of lubrication and siezes.
   / One step closer to zero emission power equipment #148
I was up at my cabin this weekend cutting up some old slash and burning it since there was 10 inches of fresh snow on the ground, I thought about that claim of 3% loss with each 1000 feet of elevation gain, since I was at 10k. I was using my stihl 361 and it was tuned for slight 4 stroking out of the cut and it cleaned up in the cut, I don't know if it would have 40% more power at sea level, but I doubt it.
I'm sure this was done is a laboratory type setting where they can hold the fuel and air constant and measure power. Well, that's fine in a lab setting where all the factors can be fixed, but in real life we don't get fixed variables.
Take the auto tune or Mtronic saws for example. The engineers want the fuel/air mixture to equal 14.7, that is the optimal burn mixture. They obtain this by measuring the volume of air coming through the carb and adjust the fuel (richen or lean) to make the ratio = 14.7. The solenoid in the carb continually adjust the fuel to keep the saw in the proper operating range. This is all regardless of altitude as they claim they can adjust for altitude changes. Also Notice that they are not measuring the density of air, only the volume. That is a very important thing to consider when thinking this through.
So a person that can tune a saw for their conditions is just like an auto tune saw and can still get the proper staticometric fuel / air ratio.
   / One step closer to zero emission power equipment #149
Yes I have. Have you checked out the HP output at high and low elevations with the proper mixtures at each elevation.
Back off the timing a little and richen the mixture. You might get a notice or just replacement parts!
   / One step closer to zero emission power equipment #150
i bet generac could sell thousands upon thousands of standby gens in calif for people wanting to get them before ban goes into effect...too bad they cant make them. there so far behind......i dont know if they will ever catch up. im still waiting on a 24 kw i ordered last March
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
2016 Ford F-350 4x4 Crew Cab Utility Flatbed Truck (A55973)
2016 Ford F-350...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
