M7040DTC
/ M7040DTC #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
This is for sale locally and I was wondering if there is anyway to know if it's Tier 4 or not without actually having to go see it in person or call somebody on the phone? I'll probably do that next week anyway since there have a few tractors there that interest me.
Other then the missing front bucket, is there something that I should be aware of concerning this tractor? Is the 8 speed transmission able to go super slow for those tough areas where speed is the enemy? Is the AC up to dealing with the heat and humidity that we have in the South?
Thank you
/ M7040DTC #2
the MXX40 series is non Tier IV, what they called Tier II at the time. looks good, would be nice to have service log
purchased my M8540 in '08. 2 transmissions are aval for the models,; the 8 sp std (that this one has) & the 12 sp hd hyd shuttle (that i have). personally, i'd prefer the 12 sp heavy duty (has a greater 3ph lift capacity as well) the 8sp has a single dry disk clutch: i definitely would want to check that personally before buying. the hyd shuttle (wet clutch pack) will outlast dry clutch & it's very handy to have the 4 extra gears for creeping, etc.
the 1153 loader has approx 2500# lifting capacity. my model is open station, so can't say about cab A/C
Jeff is always good at providing specs, etc good luck
/ M7040DTC #3
Looks like my M7040. Mine is a 2006 model with 3 rear remotes and Kubota front remote. I love mine and have about the same hours on it. The lowest speed is not a crawler gear but is pretty slow and has 4 speed with 2 ranges. It has hydraulic shuttle gear system to reverse very easily.Have had absolutely no problems with mine. AC and heat is working really well. Looks like I can sell mine for more than I paid for it 15 years ago. Let me know if you have any other questions
/ M7040DTC
What size mower do you pull with your 7040?
/ M7040DTC #6
Thank you
We have a 7060, but the not so obvious 8 vs 12 differences I am aware of are:
1. 12 has more hydraulic flow (in case you need it for implements)
2. 12 has hydraulic wet disc brakes
3. 12 has ePTO standard (you can get it optional on the 8)
4. 12 has electric-hydraulic 4WD (this might actually be a bad thing IMO)
Great machines, I am sure you will be happy with it.
/ M7040DTC #7
The mower that I use with the M7040 is a 15 ft woods batwing
/ M7040DTC #8
Also have the optional air suspension seat which is very comfortable
/ M7040DTC #9
have an 8' 3ph twin mower (2000 lbs) that the 8540 handles with ease, prob could go larger but it fits my needs perfectly. much prefer the lift type over the pull type or bat wings, all a matter of application. i'd seriously wait for an hyd shuttle model over the shuttle shift in that series...
when i purchased the tractor in '08 i don't think the heavy duty 12 sp was avail in the 7040 model, tho it could have become avail in successive yrs before being discontinued in '13. however, the hyd shuttle was available as i owned a 7040 with hyd shuttle before upgrading to the 8540. (probably the best move i've made in a tractor purchase...) i suggest patience in your search
best regards
/ M7040DTC
Thank you. I'm not in a rush at all, but in my experience, Winter is when prices are at their lowest and inventory is at it's highest. Once Spring hits, there will be more buyers.
I have never run a batwing before, but after using a 6 foot cutter for the last 18 years, I really want to go with the biggest mower that I can get!!! I'm just nervous that a 70 hp tractor can handle a 15 foot mower. My neighbor does it with a 70 hp Zetor, so I know it's doable. I've been thinking 12 foot would be better, which is why I'm only interested in 70 hp or bigger.
/ M7040DTC #11
My m7040 runs the 15 ft batwing with ease and even going up slopes it has no problem keeping up speed. The batwing is a regular mower and leaves a very nice cut. It will have some difficulty cutting longer grass of over 6 to 10 inches since that is not what it was designed for. I have it connected to each wing so I can raise them as needed for clearance.
/ M7040DTC #12
wise thinking. not familiar w/bat wings, but would look at the hp rating of the mower gearbox. think the 7040 has low/mid 60 pto hp. in terms of mower/tractor limitations, you might post your circumstance in the attachments forum. best of luck
/ M7040DTC #13
The Kubota 7040 seems to be an awfully popular tractor used by the road right-of-way mowing folks in my area. I'll have to look to see what size mowers they pull.
Some of the previous posts mentioned that the two different transmission options also differ in hydraulic flow. That might be more important than you think if you're ever thinking of a hydraulic auger or post pounder in the future.
/ M7040DTC #14
We were told 12 ft would be ok. The Athens Kubota dealer sells a bunch of 60 series and mowers. However we still use weed slingers and a bush hog. No batwing. We mostly cut hay the rest of the time.
/ M7040DTC
I looked at this tractor yesterday and I really like it. I also looked at several other brands of similar size and some that where a lot bigger. What really struck me is just how much I liked the size of the 7040. The bigger tractors just seem too big to me. I just want to mow my open area and keep the weeds down, and to be able to carry round bales around. I didn't start it up or do anything with it, I just sat in the seat and walked around it. I talked to the sales guy and he said that they didn't finance anything, and to go to the bank down the road if I wanted a loan. That kind of put me off. I'll talk to my bank later this week to see what they say, but I'm not expecting too much since it's a ten year old tractor.
/ M7040DTC #16
I love our M7060. Yes it is a great size. We move bales and mow with it all the time. The shuttle transmission is smooth, FEL is very responsive and smooth. My Dad and I demoed a Deere 5 series and the Kubota M series 2 Summers ago when it was 105 out...the deciding factor was the AC in the Kubota. Much better. It gets so much use last time I was back in TX I had to do his required service, and he got scolded for not doing it already! We also used it to put up a squeeze chute system (Priefert) for the cattle, very useful with fine movement and tighter quarters. Im headed back this Sat for a week, cant wait to get some more seat time on that machine. Very nice machine.
/ M7040DTC #17
I've borrowed my neighbors 12 foot bat wing. It's a tow behind - not a 3-point. My M6040 powered it just fine. Mowed my larger meadows. Meadow grass was about 8 inches high. I mowed at the lowest setting - around 2 1/2 inches.
HOWever - if I were to purchase any type of "bush hog" type mower - I would first figure out something to combat the damn dust. My M6040 is open station and that big 'ol bat wing really makes the dust, wild pine needles, trash, debris - etc.
/ M7040DTC #18
Yes in TX we cant mow anything without dust...makes a cab so, so nice. Dust, hornets, heat...so nice.
In CO by contrast no dust, no stinging insects, no heat in the mountains in the spring, summer, fall so I like open station. Winter...not so much.
/ M7040DTC #19
That's a nice used tractor. Flint is just down the road, south from me.
/ M7040DTC
When I posted this, they wanted $34,900 for it. I noticed today that the price has gone up to $39,500. I like a lot of things about this tractor except the transmission. I also thought it was overpriced before, and now it's grossly overpriced. Hopefully this trend comes to an end, but I honestly worry that it's just going to get worse.
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A61567)
2014 Jacobsen AR3...
2006 Ford F-550 Flatbed Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2018 Nissan Rogue SUV (A61569)
2018 Nissan Rogue...
