6284 rear pto cylinder seal needed
   / 6284 rear pto cylinder seal needed #1
hugo454
I have a 6284 tractor that needs a seal for the rear pto lift cylinder.I can't seem to find the part # on any of the schematics.Any help would be appreciated even though answers pertaining to this particular tractor are far and few between.
   / 6284 rear pto cylinder seal needed #2
if you read thru this older thread, may help a bit ...
Great, Thank You,
It will be very helpful, however no parts breakdown and the schematics that I have found online do not reference the individual components of the lift cylinder.I'll just live with the leak(which is slight) until the day comes that it bothers me enough to merit removing the cylinder and sending it out.
That service manual is great and will help greatly when I need to troubleshoot.
Shame that info. on these tractors is so hard to come by.
   / 6284 rear pto cylinder seal needed #4
Great, Thank You,
I have an 08 CC 6284, my rear PTO arms will not lower. I turn on the PTO, engine revs up, push the lever to lower arms and nothing happens. Do you think I need a seal as well? I don’t see any leaks. I also cannot find a relief valve knob on the PTO. Usually I’ve seen knobs on John Deere and Kubota to release hydraulic pressure. But I cannot find a knob on the cub cadet.
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
40' CONTAINER (A54757)
