Engine Oil change away from KUbota brand?
   / Engine Oil change away from KUbota brand? #1
TWD
Gold Member
Sierra Nevada Mountains - CA
Kubota M59
Anyone switched from the Kubota Brand oil 15w40 to T6 5w40?
I noticed my jugs of kubota 15w40 over the last few years are not identical oil types anymore so I'm not sure what may have changed... but I did notice when it's < 45*F it's noticeably rougher starting.
I have T6 5w40 on hand already as I use it in various other engines... thoughts? experiences ?
   / Engine Oil change away from KUbota brand? #2
What does your owners manual say for winter operating temperatures? that's the first place to look.
   / Engine Oil change away from KUbota brand? #3
I use T6 Rotella 5W-40 in my L3830GST and my RTV1120 because I use them year around. My ZD326 gets T6 in 15W-40 as it’s warm weather use only.
   / Engine Oil change away from KUbota brand? #4
Use the T6, your Kubota will thank you.
   / Engine Oil change away from KUbota brand? #5
All my diesels run T6 5w-40, 2 Kubota's and its a marked improvement on cold start.
   / Engine Oil change away from KUbota brand? #6
For engine oil I buy what's on sale - 20L pails of T6 work great
   / Engine Oil change away from KUbota brand? #7
T6 is all I run in both my Kubota diesels, as well as several other small engines
  • Good Post
Reactions: TWD
   / Engine Oil change away from KUbota brand? #8
Whatever oil meets the tractor specifications.
Different brands of oil are all bottled on the same production line.
   / Engine Oil change away from KUbota brand? #9
Kubota seems very restrictive in my owner's manual. But on their web site they clarify that weights over than 10-30 or 15-40 can be used:
Kubota | Lubricant & Grease Maintenance Schedule
I switched my tractor to 5-40 and it's doing fine. Have not had a cold start yet but I now keep a small milkhouse type electric heater in the garage anyway.
   / Engine Oil change away from KUbota brand? #10
I use that oil in my Dodge Cummins motor and cold weather operations are much better. IDK about small Diesel engines but I’ve been tempted to run it in my tractor.
  • Good Post
Reactions: TWD
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
2002 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2002 Ford F-250...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
