Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #18,761
I bought a new trailer to haul logs to the mill and haul lumber and materials home. Here is loading logs near my house preparing to go to the mill.
Nice smooth loading operation. Simpler set-up than a parbuckle rig. Do you have any pictures of how you have that winch rigged?
gg
   / Tractors and wood! Show your pics #18,762
Yesterday I converted an old skid trail into a tractor road. It runs between two other tractor roads to give me a good loop thru some ash firewood and some fir. First I hand cut the small trees that had grown up at ground level. Here are a few before and after pics at different spots. The new road heads down hill from where it tees off.
Rocks and stumps typical in a skid trail were easy work for my little dozer.
Since there are no ditches I try to keep some slope across the road so the water will run off to the low side and not be channeled down the road.
More of the same and where I stopped for lunch.
gg
   / Tractors and wood! Show your pics #18,763
gg
Beautiful area!
But come on, where's the pictures of the "little dozer" doing some work? ;)
   / Tractors and wood! Show your pics #18,764
It's hiding in that last pic! Is that a dresser, Gord?
Beautiful woods and trails. Do you seed them with shade-grass or anything?
   / Tractors and wood! Show your pics #18,765
Beautiful area!
What I did yesterday was pretty mundane. But it can push when it has to. This was on the same type but more serious job a while back that I have shown before. Dresser TD7G, 70 hp, 14500 lbs
gg
   / Tractors and wood! Show your pics #18,766
NICE looking logs!! What do you use to get them from the woods to the trailer? Those are a little bigger than I like to do, not sure my tractor could pick them up or that I could turn them over while on my mill.
The tree company the dropped the tree put them along side the road. I just had to pull up along side and load them with the winch.
   / Tractors and wood! Show your pics #18,767
Here are some picks of using the snatch block to pull up the logs. Because I had the 4x4s on the trailer, I was able to pull from underneath of the other logs.
Love this setup.
   / Tractors and wood! Show your pics #18,768
gg
My grandfather had a Dresser and loved it. My father left us boys with the JD 450C both great machines and used for exactly what is pictured here.
   / Tractors and wood! Show your pics #18,769
Dang. You put a lot of thought into this trailer, Ed. Frickin awesome.
   / Tractors and wood! Show your pics #18,770
Very nice Gordon!! And beautiful woods! How much property do you have there?
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
1041 (A50459)
1041 (A50459)
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
