Ford 1700 fuel injection question
/ Ford 1700 fuel injection question #1
geozeitl
Green bay wi
Ford 1700
Hopefully finishing up a rebuild on my ford 1700. All timing marks are right on. Had fuel injector rebuilt also. Before l put the head on l wanted to see when the fuel is injected to the cylinder.While turning the crank l could see fuel popping out of the pump fittings where the fuel line is. The cylinder postion was only 1/4 way to TDC when the fuel would pop out,would that be about right ?
Just hoping fuel injector pump rebuild don't affect the timing
/ Ford 1700 fuel injection question #3
I have not done that particular job. Can post the timing procedure later tomorrow. The injector repair should not affect the timing. it should be timed with cam shaft and crank shaft gears on the tractor . If you put witness make on gear location against the cover and other gears on disassembly then the timing the not be affected. Minor adjustment of the pump externally could advance or ****** spray timing for fine tuning. For that you would use timing mark on the crank shaft notch. Again, I have not done that and what I said is based on the reading the manual. Did the injector open up in the down stroke or up stroke of the piston?
It was on the up stroke
JC you helped me with posts before thanks, do you still have your ford 1700
/ Ford 1700 fuel injection question #6
sure , yes I do, No plan to ever part with it if I have a say in it.:D
Can dig up parts in the manual on how to fine tune the pump if you would like.
Sure thanks , some people that have the 1700 never seem to have issues, me on the other hand, I'll have a degree in diesel mechanics when lm done with her
/ Ford 1700 fuel injection question #8
I have had some minor issues with mine, but they were all wear and tear and age related stuff plus some very basic routine. I try to learn as much as I could to avoid overheating, engine lubrication and injector pump issues. Make sure you have 2 oz of the same engine oil in your injector pump as it does not share oil with crankcase. Attached you'll find info you need.
  • P48-49.pdf
Thanks what did you do to prevent overheating issues, l know it's something to watch for on this model with cracks in the head
I never liked the battery placement on mine ,right in front of the radiator, you think you would want a free flow of
air across the whole thing
/ Ford 1700 fuel injection question #11
You would think that, but at the same time many makes and models have it there for ease of access and plus where else could they put it ? on a bigger rig they might have more option. I actually other than middle of summer put a 8x8 or 12x12 piece of cardboard between the radiator and the screen in front of it. That allows my rig to come to normal operating temp as diesel would not like to operate cold. My radiator and block is clean and I use leaf blower almost after each use to clean out seeds and derbies so intentionally blocking some air works to my advantage. On my Kubota, it is even harder to bring it to temp for most of the work I do , so blocking the radiator partially is a way to go. Saying that I always have my eyes on the temp gauge.
/ Ford 1700 fuel injection question #12
Refer to post #11. I have cleand and flushed block and radiator. I have an overflow for my radiator than I can watch very easily. Tractor is always parked in the barn, so if I have a leak I know. I do have a habit of constantly keep an eye on analog temp gauge, prefer them over idiot light any day. You will be surprised even with screen how much of fine dirt fins collect and as they accumulate causes overheating. I keep an eye on water pump also and since I am not making money using my rigs hardly ever do it in a hurry. I check oil and water very frequently almost always before I get on the seat for most parts.
Good to know, do you use any attachments with it
/ Ford 1700 fuel injection question #14
The battery on my Ford 1310 is also forward of radiator and it's never been an issue as far as blocking air flow.
The only time screen in front of the radiator tends to clog up often enough to be an issue is when mowing pasture of tall hay in mid or late summer, but I think that would happen with most ordinary tractors.
Hey thanks for the info, would always think during the summer months it cause alot more heat build up
/ Ford 1700 fuel injection question #16
I use all the attachment in my signature with the exception of the dirt scoop since I have a loader tractor for the last 9 years. All my implement is sized to match my Ford 1700.
/ Ford 1700 fuel injection question #17
Hopefully finishing up a rebuild on my ford 1700. All timing marks are right on. Had fuel injector rebuilt also. Before l put the head on l wanted to see when the fuel is injected to the cylinder. While turning the crank l could see fuel popping out of the pump fittings where the fuel line is. The cylinder postion was only 1/4 way to TDC when the fuel would pop out, would that be about right ?
The pump timing is advanced so the injector should start fueling before TDC on the compression stroke to allow for the time of injection (it's not instantaneous) plus a lag for compression ignition of the fuel. I believe the static timing is around 26° BTDC. I'm not sure what that would be in stroke but it seem like it would be 180°-26° = 154°░in crankshaft degrees.
However, you were looking at the pump output not the injector output. You should hook up the injectors to the pump and then run the experiment. It takes some pressure to fire the injectors.
Thanks Jerry, my cylinder head should be back today. I'll try before I put it back on
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2013 PETERBILT 365(INOPERABLE) (A65643)
2013 PETERBILT...
Dirt Dog 3PBU Hay Unroller (A65579)
Dirt Dog 3PBU Hay...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
