airbiscuit
Super Member
- Joined
- Aug 28, 2004
- Messages
- 7,512
- Location
- NW Wisconsin
- Tractor
- New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
I know that it's best to never run out of fuel, so I never let my tractors get below 1/2 tank. That said, I've still had to bleed/prime my system.
Experience #1 - Had a New Holland TC 21D that started running poorly. I noticed a lot of water in the fuel filter bowl, so I changed the filter, but I either lost the prime, or there was too much water in the injector lines. Loosened the fittings at the injectors, cranked the engine over a bit and re-tightened the fittings. Purred like a kitten again.
Experience # 2 - I cracked the fuel filter bowl on my Kubota L 3010. It was at our hunting land, so I replaced the filter and bowl in the field. I knew about losing prime, so I made sure the fuel bowl was full before I tightened it down. It started right up, ran great, then quit. My heart sank. This was my first fuel filter change on the Kubota, and I wasn't familiar with how Kubota deals bleeding the system. I went home and read the manual and found out that all you have to loosen a knob on the injector pump and crank it over. Tighten it back up once it starts. It couldn't have been easier.
Lesson Learned - Familiarize yourself how to prime/bleed the system on all your tractors before you need to. The day may come at the most inopportune moments.
Would like to hear the experiences of others for the benefit of other TBN members.
