Massey Ferguson 1405 dozer blade
   / Massey Ferguson 1405 dozer blade #1
tepsguy
Archbold, Ohio
Massey Ferguson
I was looking for a snow plow blade for my MF 1528 and have found a used 1405 blade with sub frame which from what I found on the internet this will fit my tractor. Have a couple concerns before buying it first I have a loader on my tractor which comes ooff easily not sure if the subframe for the dozer blade will interfere with the loader. I assume I can still buy from MF the installation instructions. Hopping someone out has a similar setup that can share their wisdom.
   / Massey Ferguson 1405 dozer blade #2
You will need to remove the loader to use The blade.
I have the same set up on my 1528, but mine is used for a front mount snowblower which I really like. No issue really as the loader comes off quickly as you know.
Enmark Z Spray (A53316)
Enmark Z Spray...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
KOMATSU AVANCE UTILITY WA50-3EO WHEEL LOADER (A52707)
KOMATSU AVANCE...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
