GC17xx front wheel camber
/ GC17xx front wheel camber #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
Look at that front right wheel, what's up with that? Should I be concerned? Everything seems to work fine.
/ GC17xx front wheel camber #2
What am I looking at of concern?
/ GC17xx front wheel camber #3
Did you check the bolts holding the wheel?
Anything seem loose on that side?
No, nothing evident. Just weird that one wheel is more cambered than the other. Can you guys with GC's take a look at yours while on level ground? Maybe that's just a "thing" with this tractor, dunno.
/ GC17xx front wheel camber #5
Mine are definitely cambered. Wheels both at equal inflation?
/ GC17xx front wheel camber #7
my 2010 gc2400 has a camber like that (maybe not as pronounced) BUT is equal on both sides.
if I had to guess its the OTHER side that is off spec.
with that being said....if everything works just drive on...
Hwhaaaat!?? Now you got me thinking, and that thinking is that either me or the previous owner did too much loader stuff w/o adequate counterbalance on the back, and maybe a little bit messed up the axle or cv joint on the left side over there. :oops:
But like you said, if everything is working, maybe no biggie?
/ GC17xx front wheel camber #9
Hey Gene, both of my front tires look even and similar to your right side tire.
You probably already looked at these suggestions I'm thinking of to check/adjust are:
Front tires toe-in, & air pressure ratio stated in my owners manual (front tire pressure to rear tire pressure).
Just a guess, maybe your mower has more down pressure to the ground wheel/s on the right hand side versus the left hand side (if so it may act like a jack raising the right hand side some a long with less weight on the right side tire)?
Yeh thanks, yeh I gotta take a closer look at all that for sure. The whole time, I was concentrating on the more cambered right wheel, didn't even think to look at the other wheel. Doh!
/ GC17xx front wheel camber #11
so was bored and just went out and looked again. both my tires have a camber close to ( not as pronounced but that may be just model difference) to your rt side tire.
your real issue, IMO, is the left side tire has LESS camber.
so yeah, possible overload/slight bend/etc.
as far as mower weight...looks like its on ground so should not be issue. suspect you are correct about loader work.
but if it ain't broke don't worry.
worse case...close one eye when looking at front of tractor LOL
Daaamn GeneV, stop being so judgmental! :LOL:
Who am I to judge...even with the wheels at different camber angles, tractor is still more perfect than I can ever hope to be lol.
/ GC17xx front wheel camber #13
oddly enough (since mower mentioned) this is sort of related to issue I have.
my mower lift rod is bent enough that rt side (heavier discharge side) is bent enough that there is almost 1.5 inches difference in lift height after 11+ years LOL
Gonna replace rod when I store deck for winter.
But I digress, I'm bored right now LOL
Does your lawn looks like a black dude's hairstyle from the 90's?
/ GC17xx front wheel camber #15
LOL nope I adjusted lift so its even. once I pull deck for good in week or so I'll replace he bar.
/ GC17xx front wheel camber #16
As long as that rim doesn't wobble there isn't anything to be concerned about. The hubs are casted so other than shims it can't be changed.
It could be the rim too...try swapping wheels to see if it makes a difference just out of curiosity.
Hmm, that's a good suggestion, will try that yeh!
