YM 2210D front axle arm and top knuckle
   / YM 2210D front axle arm and top knuckle #1
Johnawild
YM2210D
I just bought a 2210D not knowing the parts are hard to find... can anyone help me!!! And I have a few questions... does the 10 series have interchangeable parts?
   / YM 2210D front axle arm and top knuckle #2
Did you download the FREE manuals yet. They can help to answer your questions.
Manuals are at the Yanmar Tractor Owners Group, the link below in my signature. ;)
BTW, there are 2 parts manuals, early model and later, so get BOTH just in case.
IF you don't use the YM in front, some will think you own a Mitsubishi tractor with that model number.
This is from the early model parts manual.
This is front the later (newer era) model.
   / YM 2210D front axle arm and top knuckle #3
'some' of the -10 and -20 series are swapable in the correct tractor family. There is a thread here about Yanmar Tractor Cover pages that goes into those depths. Basically all that changed was the engine had more power or the machine was gear vs. PowerShift on the floor or PowerShift on the steering column at the dash.
Ah ha, caught your other posting in the newer Yanmar thread. Looks like you are looking for the knuckle & kingpin assembly. Those are RARE. Yet, someone did their homework months ago and found out that the John Deere 790 4WD assy was a perfect drop-in for their YM model.
   / YM 2210D front axle arm and top knuckle #4
You have the 10 series? Did you mean you have a 2220 maybe? Not sure if the later exists? I guess it does?
   / YM 2210D front axle arm and top knuckle #5
A 2210 is a pretty common tractor. I bet pretty much everything you need can be had? I'm sure the big gears up front might be harder to find but you would really have to abouse it to destroy the actual gears I would think 🤔?
   / YM 2210D front axle arm and top knuckle #6
Both do. :)
YM2210(D) and YM2220(D) along with YM2202(D) that is more rare.
The YM2210 is a very oddball machine. It's a 2-cly ! And it has the very RARE 2T90 engine. Not many were made. It's somewhat related to the JD650 with the 2T80 engine. Some parts do swap, but not all. And the JD950 with the 3T90 engine can use the pistons and rings. Thus between the 2 Deere Yanmar engines, a 2T90 can be mixed and rebuilt.
I sent it to repair shop... and they lost the parts and everyone quit... so this is what I have left!!!
Both do. :)
Thanks that’s the most info I’ve got !!! Thanks
   / YM 2210D front axle arm and top knuckle #9
WOW. o_O
IS there a way to mount the wheel on and make it a 2WD till you get the 4WD parts?
This tractor only has 100 hours on it... sat for years... starts right up!!!! Wish I could just find someone with the whole assembly... together and buy it from them.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A57024)
Neckover GL24-2-7K...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
RURAL KING RK25H TRACTOR (A57192)
RURAL KING RK25H...
