UTVHitchworks Farmboy 3-point Hitch for 5600
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #11
Toolcats are great machines. Traction is lacking a bit in off road conditions. I know this will excite a lot of conjecture from their owners. The newer units have the traction control which helps a lot, too.
I wonder how much the traction would be improved with tracks at the 4 corners rather than tires? Or would there be a way to run tracks on them?
It would be amazing to see a Toolcat-type machine that has a side by side cab, but has more robust off road traction and clearance for tasks like cutting brush in muddy areas.
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #12
Well, you can get snow tracks for a Polaris. I wouldn't think working tracks on a Toolcat would be much different. Maybe beefier. I like the Toolcat visually. I've never been in one. I would think it would be awkward to get used to pulling some 3 PH implement with it.
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #13
I run my rotary cutter, tiller, snow blower, rear blade from the rear and a snow plow, bucket, grapple, finish mower off the front. Compared to a tractor, the TC doesn't have the lift height but it gains control because the work is closer to you. With the compact size and AWS, it can fit in small areas. Using a front and rear plow allows me to plow in each direction saving time. The tight package lets me maneuver between the garage/shed area without jockeying around much. Tracks are available and yes they are HD.
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #14
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #15
Sometimes it is better to push a 3 PH implement :D
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #16
I like that. One of those would be nice but it doesn't replace a tractor and I can't have both.
   / UTVHitchworks Farmboy 3-point Hitch for 5600 #17
2019 Deere 550K (A53317)
2019 Deere 550K...
2021 Ford Mustang Mach-E AWD SUV (A56859)
2021 Ford Mustang...
Craftsmen Air Compressor (A57454)
Craftsmen Air...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
43024 (A59228)
43024 (A59228)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
