Ford 6.0 diesel; the good, the bad, the ugly?
/ Ford 6.0 diesel; the good, the bad, the ugly? #181
That’s a maxed out truck. Keep in mind the 2019 and 2020 Cummins 6.7 engines use the problematic CP4 high pressure pump which is also used on the Super Duty from 2011-current.
/ Ford 6.0 diesel; the good, the bad, the ugly? #182
And that’s the 100th time that truck has been “maxed out” in the last year and a half. Actually it’s been beyond maxed out.
All the new diesel trucks are problematic. I just came off 20 years of mostly Ford diesels used in heavy farming and snowplowing use and looking back on it, they were extremely disappointing trucks.
/ Ford 6.0 diesel; the good, the bad, the ugly? #183
I just pulled on the scale at 46,700lbs today with my Ram/Cummins/6 speed. Never felt the need for 8 or 10 gears.
Damn glad I have a Cummins now. It lives under 3,000RPM and just begs for more.
I would never consider owning anything but Cummins for heavy, hard pulling purposes.
My F-750 is set at at 245 hp around 650 torque with a baby 5.9. The 6 speed is lacking IMO for the weight and power combination. Especially on the top end. Even one more gear between 4-5 would make a lot of difference. But the Cummins does have the best towing performance of anything I’ve had. I’ve also got another Ford with a v-10. I’ll take that way before I’d take any of the powerjokes. For one the gas burners are cheap to buy. 2 they’re cheap to maintain and repair. The mileage sucks but the return just isn’t there for a diesel.
/ Ford 6.0 diesel; the good, the bad, the ugly? #184
I run a landscaping business and I buy quite a few trucks. I’ve had four Ford 6.7 trucks and now two RAM 6.7 trucks. No problems with either, but I don’t keep them long enough to be a problem, except this old 6.0 Ford which I just enjoy for some reason.
/ Ford 6.0 diesel; the good, the bad, the ugly? #185
Hey that’s cool. It’s the “character”
I dig that.
/ Ford 6.0 diesel; the good, the bad, the ugly? #186
I'm still kicking tires on ton trucks... mostly looking on Craigslist for something below the rust belt. My criteria is pretty liberal; manual shift, heavy 3/4, but preferably a ton truck. Right now I'm looking at mid-2000, as they are in my preferred price range for a truck which will probably see 5000 miles per for the next few years, then a lot less after that.
Currently I find this F350 rather interesting [FONT=Verdana,Geneva,sans-serif]https://atlanta.craigslist.org/eat/cto/d/monroe-2006-ford-f350-super-duty/7032105466.html.
I may consider taking a ride down next year (month), assuming they still have it. The 6.0 makes me nervous though, it seems like the Ford Diesels of that era had some growing pains as they were introduced to emissions.
[/FONT]
That powerchoke engine is a disaster. Get something with a Cummins motor.
/ Ford 6.0 diesel; the good, the bad, the ugly? #187
I'd get a cummins motor as long as it wasn't in a dodge pos. 🍻
/ Ford 6.0 diesel; the good, the bad, the ugly? #188
Somebody will be around shortly to school you on dodge vs ram. Like it makes any difference.
/ Ford 6.0 diesel; the good, the bad, the ugly? #189
Oh yea dodge sucked so bad they had to change there name to ram. 🍻
/ Ford 6.0 diesel; the good, the bad, the ugly? #190
Hmmm, haven’t seen a 7.3 power stroke for a long time. Lots Of 12 valve cumins around. There’s about four within a two block radius of where I live.
/ Ford 6.0 diesel; the good, the bad, the ugly? #191
They run forever. A true medium duty engine and more if you ask me.
/ Ford 6.0 diesel; the good, the bad, the ugly? #192
Soon, they'll have us all running electric trucks and tractors with chinese batteries. Oh, we can keep our diesel equipment, but the price will be $15/gal
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
PAIR OF DIAMOND PLATE DBL AXLE FENDERS (A62130)
PAIR OF DIAMOND...
Butler MFG Water Tanker (A63118)
Butler MFG Water...
(24) Ratchet Tie Down with Toolbox (A61166)
(24) Ratchet Tie...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
