Help Choosing Machine for First Timer- Big Lawn, Long Driveway
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #1
Madams135
None yet
Hey folks, looking for some advice. Just purchased first home in upstate NY and am seeking opinions on a machine to maintain it. Property is 10 acres, ~6 of which are very flat, mowable lawn with minimal obstacles. The rest is wooded/swampy, which i won't be doing much work in. Possibly some woodcutting for garage woodstove at some point. The driveway is shared, but owned by me. My section total is ~1200 feet, flat, paved with two straight shots (one of which is wooded). Snowfall is about 75 inches per year. We always get a couple noreasters that will dump 1+ feet, sometimes 2 or 3.
I currently am using a 54' Husqvarna ZTR that takes me ~3hr to mow the lawn. At full clip and mowing only once per week, it does tend to bog down/clog at times, slowing me down further. For snow removal, I currently have nothing. I also have no truck. So now to the point, i am exploring getting a machine that could handle both duties, while keeping both speed and price in mind. The alternative would be a used plow truck, while keeping the lawn duties assigned to a ZTR(possible upgrade in future to 62'). A crucial point is that i work 13 hour shifts 3-4 days in a row, so speed is fairly important when im already waking at 430 a.m. I know a truck wins here, but with current truck prices, is a beater plow truck going to be worth the headache? No interest in buying new. Ive also got an opportunity to buy a 2006 trailblazer with a small homesteader plow for ~5k. I fear this will spend more time being fixed on my lift than actually plowing. Final option is to get a quote for a plow guy, which keep in mind my neighbor would halve to split cost.
So obviously you all are biased to tractors :), so thoughts and opinions on what you would do and what size/model of tractor if so? Thanks!!
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #2
I only know the Kubota series so my suggestion leans toward the B or LX series. I believe you can get them with a six foot belly mower which should speed mowing. It runs from a mid PTO which would allow a front snow thrower. I do not know how fast it would run through snow, though. You may want loaded tires or chains for extra traction.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #3
If speed is "fairly important", IMHO I don't think your going to find a tractor that will mow as fast as a ZTR or plow as fast as a Truck. This is not to say a tractor would not do both. Do you have any other real uses for a tractor (granted if you had one you would use it... but do you for see using it enough to justify the cost?).
We live in N.E. CT & we have 2800+ ft of drive with a combo of wooded area & open area, we mow about 3.5 / 4 acres of our 20... we have a 40hp tractor, a plow truck, a ZRT (etc, etc) & all are used for different tasks. I rarely use the tractor for snow (even in 12-14" storms), it does not have a cab & the truck is much faster to clear with (& it is warm inside). The tractor is used to move back piles when needed but almost never for actual snow removal; it just doesn't work well for us. Our neighbor has around 2000' paved drive & plows with his truck, he owns a PTO blower for his JD & really only uses it on really big storms or to move back piles. When I asked him why... "Plow is faster... got to get out to work"
Our tractor would be terrible to mow with, to big & would destroy the lawn & way to slow... won't trade the ZRT & it only has a 50" deck; we actually downsizes from a 64" & cut down on our mow time because of the layout of the property.
I'm not suggesting a tractor is a bad decision for your scenario, & many, many on here use their tractors for the same tasks & it works for them. You just you need to balance your time & effort, your usage, & your investment, none of this equipment is cheap, but you already own a ZRT. If you have the use / justification for a tractor & are willing to possible sacrifice the speed of each process then they are one of the most universal tools to own as a property owner. but not always fastest (or the best) at a given task.
Maybe get quotes for your first year of snow (split it with the neighbor) to get a feel for what conditions will be like.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #4
I work 13 hour shifts 3-4 days in a row, so mowing speed is fairly important.
I currently use a 54' Husqvarna ZTR
Consider at Ventrac with a 95" wide area mower. Ventrac is a division of Toro.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #5
For snow removal, I currently have nothing. I also have no truck. So now to the point, I am exploring getting a machine that could handle both duties, while keeping both speed and price in mind.
You didn't mention a budget, but the best costs more due to the quality.
A machine that could handle both duties is the Toolcat from Bobcat. It is used by many commercial snow removal companies.
I don't need it for snow removal, but do use a 5610 for Mowing with a 6' finish mower:
Or the 7' brush hog:
See what else it can do here: Toolcat 5610 F and 5610 G Series Pictures
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #6
I have a similar type lot as the OP and my TC33D was a very good fit and was a great tractor. Yes, the Toolcat replaced it because I wanted some comfort and the wife can ride along. The OP should talk with the neighbor on what worked for snow removal in the past. Also, there is limited product supply at the dealers right now and we are nearing winter. You don't have to rush trying to make the perfect choice this year. Get what you NEED now and fix it later.
Thanks roadworthy. I was definitely eyeballing these two Kubota lines as my options, so glad to know im looking in the right ballpark here
This is great insight and much appreciated. As far as other tractor uses, i think it would be minimal and not enough to justify cost. Moving a tree here and there, moving some rocks, and tilling the garden. But those are all things that i can rent for when the time arises, or use an alternative. Your last statement makes a lot of sense, and was something i was seriously considering more and more. A year of collecting data would probably help with making the right decision. I don't like having to rely on others in the event of an emergency, but for this year it will be just the wife and i with no kids yet, so that helps ease the anxiety for now.
These are neat! Never seen them, thanks!
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #10
I also live in upstate NY but near the NY/VT/MA border on the Taconic range and we average about 80"-100+ of snow a year. i have lived here 30+ years. My driveway is well maintained gravel about 1100 feet long. I mow about 4 acres of lawn, snow blow the driveway after the snow stops. I do it all with a JD 2032R with 59" snowblower and 60" finish mower.
View attachment 716018View attachment 716020View attachment 716021
You had me until i saw the price tag hahaha. Maybe someday. That's an amazing machine, thanks for sharing!
That's great, thanks for the input. How long does it take for a mow for you? And to snowblow, say 6"?
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #14
I’ll second the idea that no tractor will mow as fast as a zero turn. For reference, my 38” zero turn is faster than my 60” Kubota BX, in places with obstacles. However, my BX MMM (mid-Mount more) is incredibly versatile. I’ve mowed things in places no mower should ever go.
I guarantee your 54” zero turn is faster than my 60” tiny tractor.
As far as snow removal, I have the best results with a rear blade and bucket. I have a front mount blower, but never have used it. For some reason, since I bought a tractor, the snow has stopped falling (not really kidding).
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #15
I'm also in upstate NY, with similar driveway and mowing requirements. I've plowed with a tractor, and with a truck, but 23 years ago switched to a 7' rear mounted snow blower on a 40hp tractor. I'll never go back to a plow. I'm mowing with a 60" Kubota ztr. I could switch to a 72" belly mower or a rear finish mower, but the 40 hp tractor is too big/heavy for the lawn and too slow.
The nice thing with a blower, you have no snow banks and you only move the snow once. It doesn't care if there is 3" or 3', one and done, with a plow you need to keep after it, 12" of wet snow or 18" of powder is a lot to plow.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #16
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #17
With 6 acres I would say keep the zero turn, no question. I would get a tractor for snow removal just because it would have other uses, while an old plow truck would just be in the way most of the year. I get along fine with a plow on the tractor and we have similar amounts of snow. You will have to figure out if you really need a blower.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #18
how about a grasshopper or other front mount mower with a snow blower and a 72 in deck. should speed up the mowing, a larger zero turn with more traction. and it will move snow when you need it. one engine to maintain. will mow pretty much anything grass based.
if you don't have all that many uses for a loader and 3 point implements, i don't see the need for a compact tractor. I think its crazy to mow that much if you have better things to do. my Dad is the same way though, he mows about 3 acres with a 52 in exmark. I leave my pastures for hay for the neighbor and mow around the house. maybe 3/4 acre of the 5 is mowed on the regular.
we are upgrading our tractor to assist with installing greenhouses, an orchard, and a steel building, and for snow. if we were not planning on major infrasturcure we would be looking at something more like the grass hopper.
edit, the other manufacture i was thinking of is Walker, which are made just up I25 from us in Colorado.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #19
For snow removal I think a front blade is by far the fastest on a tractor but will you run out of places to push it. A snowblower is best when the snow gets deep. I think a cab would be nice but adds to the cost. A mid mount mower will cut the grass but not any better and probably slower than what you have. Keep what you got.
I have a John Deere 2025r. That would be the smallest I would look at, larger if you can afford it. There is lots of brands that make a similar tractor.
Last, I think you would be surprised at how often you would use a tractor.
/ Help Choosing Machine for First Timer- Big Lawn, Long Driveway #20
I have had my Toolcat since 2005 and would highly recommend. It does many things well. The attachments connect in seconds or maybe a couple minutes. Very tough and well built. Buy a used one if budget is a challenge.
Yooper Dave
