No 90 Weight Gear Oil
   / No 90 Weight Gear Oil #1
Florida2610D
Member
Yanmar 2610D
I went to Rural King, Tractor Supply, Walmart, and all the auto parts stores in my county. Nobody has 90 wt gear oil. Most of them have 75w-90 and 85w-90 but nobody has any SAE 90. Anybody else noticed this?
   / No 90 Weight Gear Oil #3
What calls for straight 90w gear oil? Usually it's 75w90, 80w90, 75w140. What are you putting it in that wants that spec?
   / No 90 Weight Gear Oil #4
Probably in his Yanmar. But he doesn't say where it is. Maybe a desert? :unsure:
   / No 90 Weight Gear Oil #6
I haven't seen straight 90 weight in 20-30 years. But I haven't looked for it either. There's nothing that calls for 90 wt that can't use 80w-90 or 75w-90.
   / No 90 Weight Gear Oil #7
Pretty much any 90 weight appears to be short on the shelves, everyone has a quart but that seems to be it. Broke down and ordered online when I was trying to get enough to service my disc mower a few weeks ago. I usually keep a quart or two on hand, guess I gotta up that some.
Yep, I use it in the front axle on the Yanmar. I am a creature of habit, I ended up using 75W-90. I just thought it was strange because Rural King usually has a stack of it in the 2 gallon jugs which makes it easy to service the axle. When I couldn't find it I went straight to tractor supply and they were out too. So then it became a mission. I drove around for over an hour looking for it before I just picked up two gallons of the 75W-90.
   / No 90 Weight Gear Oil #9
Perfect. Now your axle will be covered with a lube that has a better temperature range, not that it matters much in your neck of the woods.
   / No 90 Weight Gear Oil #10
you can get it via special order from NAPA.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
2020 Kia Sportage SUV (A50324)
2020 Kia Sportage...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
