dodge man
Super Star Member
B. I’ve had people do A and it makes me nervous even if I know what they’re doing. I’ve also had people do A when I was coming head on towards them, they had time to turn but it was close enough you’d start to worry.
He is likely doing it like i do - waiting until he can see all directions before he gets over. Thus, there is never a need to get back over.Legally B. What happens if you do A, and there is a need to get back over to the RH lane quickly? Now you have the person that was behind you there. Bad idea.
Can you ALWAYS see down the road you are turning down? What if the sides are covered with trees and someone pulls out in that oncoming lane? Your answer might be “I only do it if I see its safe”, and that’s a mistake. You do it 100 times, then the 1 time you decide to go for it because nothing has happened in the past…bites ya. I know you think you can see everywhere, but its still a risk. Better to not do it at all.He is likely doing it like i do - waiting until he can see all directions before he gets over. Thus, there is never a need to get back over.
Only an animal entering the road could happen and then it is simply like one entering if you are in the proper lane and there is an oncoming car. No different.
OK, i will try again: YES, i, and i suspect the OP, CAN always see down the roads we do it on. If we cannot see, we don't do it at that intersection.Can you ALWAYS see down the road you are turning down? What if the sides are covered with trees and someone pulls out in that oncoming lane? Your answer might be “I only do it if I see its safe”, and that’s a mistake. You do it 100 times, then the 1 time you decide to go for it because nothing has happened in the past…bites ya. I know you think you can see everywhere, but its still a risk. Better to not do it at all.
